Question about Craig Televison & Video
My Craig TV Model CLC512 is stuck on 'No Programs are Shown.' Never mind. It was the SOURCE set on Cable instead of HDMI1. Thanks anyway.
  • 85 Answers
SOURCE: Source does not show up.
try doing a firmware update on the tv check the website
make sure to read all instructions how to do this nead a usb flash drive
Posted on Feb 22, 2009
  • 21 Answers
SOURCE: Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Posted on Sep 14, 2009
  • 11361 Answers
SOURCE: vizio 320m. I set it up wrong. Instead of choosing
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
Posted on Oct 31, 2009
  • 312 Answers
SOURCE: Insignia NS-L42Q-10A Setup: Wrong TV Source Chosen
You can change this option by going to the "Channels" menu and selecting "Auto Channel Search." Additional details can be foundat, under the Support tab for your TV.
Posted on Mar 10, 2010
Testimonial: "Thanks!"
  • 324 Answers
SOURCE: i am having problem setting
I do not own a PS/3, but I will try to help just in case you dont get another expert at this late hour....
It sounds like you need to save the changes on your PS/3. It is timing out and going back to default because the changes were not saved.
Hope I helped!
Posted on Feb 11, 2011
I cannot get a picture to display on my TV with the Craig model CC4003B cable.
The USB will not display video onto your TV.
You will need to find an adaptor for this that will plug directly into your HDMI.
You need to buy a 30 pin to HDMI adapter, these are relatively cheap products that you can find on eBay.
Jun 29, 2017 | Sanyo Televison & Video
I have 32" hand spree TV hooked up to satellite box with a cable connected to the hdmi 1 port. Problem locking to hmdi1 port
Check in the menu of the tv do there is any option to select the input source. If so the select there its to hdmi 1. after that turn off the tv and ON again and check do it go back to TV mode.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 24, 2016 | Hannspree XV32 32 in. LCD Television
How can I change source on Goodmansld3266d tv with out remote?,stuck on pal1??? Thank you in advance for any advise
On your TV should be buttons on the bottom or the side. Hit setup menu should have a icon for inputs, cable, hdmi1 hdmi2, selected which input you want.
Mar 04, 2016 | Televison & Video
input source button and what input did you stick the DVD player into was it HDMI1 port cause if it was you would change input source to HDMI1 from DTV input source.
on the tv you have the remote control it has a source button just left of the channel up and down + ch - buttons.
Nov 15, 2015 | Seiki 39" Class 1080p 60Hz LED HDTV...
My craig clc512 32" is working but I have no sound. Volume is turned up nice pic but no sound any suggestions on fix please!
hi, see if restoring to factory default does the trick, this is always the first suggestion for modern flat screen tvs...inadvertently setting something incorrectly can phase the sets. If this does notcure the issue please add more detail, such as how it came to
' lose it's voice, and resubmit the query please
Jun 26, 2015 | Craig Audio Players & Recorders
My Craig TV is a year old, I have volume but no picture
contact craig to get warranty service,tell them its 11 months old
May 06, 2015 | Craig Televison & Video
Cannot program my craig 32" clc512 to phillips srp5107/27 remote control
The programming procedure can be had from the user manual to this remote control. Check this link to download the user manual. If you fail to download, and wants to get details, check this link. It has details about the programming method.
Feb 10, 2013 | Televison & Video
1080p tv stays in 480p mode
Resolution is a slave to the source. It sounds as though the source is only outputting 480p. Go through the menu settings of the source device(bluray, cable, satellite box, game system) and set it to output 1080.
Jul 10, 2012 | Toshiba REGZA 46RV530U 46-inch 1080p LCD...
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Televison & Video Logo
35 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
