Question about Furniture
I have a Panasonic lounge chair model ep1004 that bought at Costco yo can hear motor running for a few seconds while the hand control blinks 5 times the everything shut off. Help
  • 9098 Answers
SOURCE: Panasonic Model NN T964SF inverter
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
  • 267 Answers
SOURCE: panasonic yh42pa20 shut down issue
there are a number of parts that may cause your problem power supply, z or y sustain boards, drive boards or panel. needs a qualified servicer to check out.
Posted on Jan 24, 2009
  • 8617 Answers
SOURCE: Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
Posted on Feb 15, 2009
  • 5138 Answers
SOURCE: Panasonic PT40LC12 turns on and then shuts off after 15 seconds
Ballast Board it what turns Lamp on Call Encompass Parts Distr. or Look on their website.
Posted on Nov 21, 2009
How to unlock Jazzy Select chair so it can start up and run
Turn on the PWC
Push the joystick forward and hold for 2 seconds or until you hear a chirp.
Push the joystick backward and hold for 2 seconds or until you hear a chirp.
Release and there should be a long beep tone, signaling that it is unlocked. Since there are different joystick controllers on these chairs and I don't know exactly which one you have this is my best guess.
Dec 20, 2015 | Pride Mobility Products Jazzy Select
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
I bought used mprv 4 hooveround, been setting for a couple years and I put new battries in it,I put it in driveand all the lights come on you can near something running when you move the lever forward,...
take the freewheel levers and move them up and down a few times then leave them both in the up position. Turn on the chair and see if it works correctly The noise you hear are the motors or motor running because one or both levers are in freewheel.The clicking you hear is the electric brakes engaging when you move the joystick Hope this helps
May 06, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
Panasonic tv power button blinks 5 times
Probably the power supply is failing.
Jun 30, 2017 | Panasonic Televison & Video
Wheelchair problem
sounds like you might have locked joystick by mistake. Try pressing and holding down the on/off switch for 5 seconds.
Jun 14, 2009 | Invacare Supply Group Invacare Pronto M51...
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Speed fluctuates randomly
Try calibrating the console. If it doesn't work, you'll need a new motor control board.
Feb 15, 2009 | Reebok 8050 ES Treadmill
Electrical issues inherent in this model?
its the problem of voltage the a electrician and get the electricity power checked of your place.the oven is getting required current so this problem is coming.
Oct 18, 2008 | Panasonic NN-P794SF Microwave Oven
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
