Question about Sony Televison & Video
Sony KDL-55EX720. The standby light blinks 3 times. I've found that its either my Main or Power board. How do I determine which board to replace? thanks
    Top Expert:
  • Sony Master
  • 73,619 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 19, 2017
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
I have Sony Bravia model KDL-55NX720 & it won't turn on.It has 5 blinking red lights.According to a diagram that I found for this TV, I have replaced the TCon Board and the LED Panel. Any suggestions?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Jun 14, 2016 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Hi I ve a sony KDL-40W2000 stuck on stdby red light flashing 4 times the stop for 3 second ??any advice please
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 16, 2014 | Televison & Video
Sony kdl-40EX403 wont turn on, standby light blinks 3 times
A 3 blink error code on this model is always a defective main board ( A Board ).
Mar 15, 2013 | Televison & Video
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I replaced the main board in my sony Kdl-32S300. When turn on power, the back light flashes 3 times then goes into standby mode after which the standby light flashes 12 times in sequence. What could be...
B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Have you set the output voltage correctly?
Mar 24, 2011 | Sony KDL-32S3000 32 in. LCD Television
Sony KDL-26s200 LCD 3 blinks from the standby light, TV wont turn on. THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also...
Look for Bad capacitors they will be swollen,vented or puffed up on Top this is the most common problemwith this set. 220uf 10v 330uf 10v 1000uf 16v 3300uf 10v
Jul 01, 2010 | Televison & Video
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
