Question about Craig Televison & Video
My Craig TV Model CLC512 is stuck on "No Programs are Shown."
Need 19 in. tv code for craig tv model#clc504 so we can enter it into dish tv system. this model is not in their system
You have this backwards. The code would have to be generated by the Dish remote control. If Dish doesn't list it, it can't be done. This is a common problem.
Sep 27, 2017 | Craig Televison & Video
My craig clc512 32" is working but I have no sound. Volume is turned up nice pic but no sound any suggestions on fix please!
hi, see if restoring to factory default does the trick, this is always the first suggestion for modern flat screen tvs...inadvertently setting something incorrectly can phase the sets. If this does notcure the issue please add more detail, such as how it came to
' lose it's voice, and resubmit the query please
Jun 26, 2015 | Craig Audio Players & Recorders
My Craig TV is a year old, I have volume but no picture
contact craig to get warranty service,tell them its 11 months old
May 06, 2015 | Craig Televison & Video
Craig clc512 wont come on push power button it turns green then goes back to red
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 09, 2014 | Televison & Video
Cannot program my craig 32" clc512 to phillips srp5107/27 remote control
The programming procedure can be had from the user manual to this remote control. Check this link to download the user manual. If you fail to download, and wants to get details, check this link. It has details about the programming method.
Feb 10, 2013 | Televison & Video
How to hook up dvd player with red blue and green connectors to direct tv box with red yellow and white connectors
The Red Blue And Green are for things like projectors they send out the 3 colours to make up the TV screen.
The Red and White connectors are right and left audio the yellow is video.
I don't think you can connect these two together. So unless the box has a scart socket and the DVD player one also you are stuck.
If there's a problem caused by a shortage of scart sockets, then can I suggest a Scart Switching Box from places such as Amazon, shown below:
Jan 18, 2013 | Craig Televison & Video
Craig 15" lcd tv Model
YES.
THE-MANUALS.COM/CRAIG- CLC501 -TV- MANUAL
ITS A FREE DOWNLOAD...
Jun 06, 2011 | Televison & Video
I have a Craig Model CLC501 and have to use both Comcast's control and the TV control in order to shut off TV. I have programmed everything else but can't seem to get tv to shut off with Craig control. Do...
Most cable supplies provide a switched receptacle on the rear of their cable boxes. Plug the power supply for the tv in there if you want the cable box to shut the tv off when you shut the cable box off.
Sep 24, 2009 | Craig Televison & Video
I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Mar 31, 2009 | Vizio L32 32 in. LCD HDTV
My craig tv model ctv-41301 wont turn on
Greetings from Belize take your set to a tech your tv is having a power supply problem.thats what you call a dead set.good luck.
Mar 23, 2007 | Craig CTV-41331 13" TV
Televison & Video Logo
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
