Question about Vizio Televison & Video
I can't change channel on my vizio d24-d1 using buttons ?
    Top Expert:
  • Vizio Master
  • 75,581 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Apr 19, 2017
How do I take the back off of a Vizio D24-D1? I need the LED Strip SN.
Taking the back off is the easy part, getting the panel apart and back together without damaging it is the hard part, below is a vid that may help, its not the same model but most vizios are similar
Feb 10, 2018 | Vizio Televison & Video
I have a Vizio D24-D1 TV that went dead after a lightning strike. I want to open the TV for inspection and repair but there are no screws to remove for removal of the back of the TV.
They tell you not to even try to open up the works on a TV. There are sections in there that will give you a shock a number of hours after its turned off. My repair man said he knows someone that was near ***** because he opened the works up and never shorted the hot section out. Not worth getting hurt over. Repair people have special tools for that.
Jan 28, 2017 | Vizio Televison & Video
We have the M220MV. Cannot change channels using the numeric keypad on the remote. I know it should be possible, the manual says you can change channels this way. If not, the last channel button would be...
Hello
Reset your Tv to factory settings. It will unlock all locks including front panel lock.
Reset All Settings
Return all Picture and Audio settings to factory default. A screen will come up to confirm your
selection or to cancel it. Press Left or Right Navigation buttons to make the selection, and then
press OK to accept it.
Setup Wizard
Use this function to return to the Initial Setup menu
Go to its user manual for Initial setup menu details.
OK.
Apr 24, 2011 | Vizio M220MV 22 in. HD-Ready LCD TV
No sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
Apr 29, 2010 | Vizio L37 Television
Ch setup on a vizio tv.
( FOR VIZIO TV MODEL VO47L )
Press menu on the remote,
then go to the icon that says TV,
then press down on the remote to change,
"Tuner Mode" for Cable or Antenna.
"Auto Search" for auto search channels
"Skip Channels" for removing the unwanted channels.
If you need a copy of your manual, go here:
http://www.vizio.com/downloads.aspx
May 23, 2009 | Vizio VO47L 47 in. LCD TV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
My Vizio plasma TV won't change channels with the remote or side buttons, but if I input a channel number, it will change that way.
Try unplugging the TV for a few minutes and then doing an auto channel search through the menu button. That has solved my problem, at least for the time being.
Aug 11, 2008 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
