Question about The Office Equipment & Supplies
Changing the roll tape - The Office Equipment & Supplies
How to change the tape roll
Facing the dispenser with the cutting edge pointed toward you slide the axle to the left
Nov 26, 2013 | Staples Executive Desktop Tape Dispenser,...
How do you open a Scotch Tape Dispenser C60 to change the tape
The entire carriage lifts out using a good amount of lifting force. Slide your finger under the empty roll from the front of the dispenser. Apply upward pressure. You may be concerned that you will break the plastic roller, you won't. the entire carriage will pop up. When it does it's a simple matter to replace the old tape with a new roll. Snap the carriage back into place to use the new roll.
Jan 21, 2013 | Scotch C60 black 2 Tone Desktop Tape...
How do I change the paper tape roll on casio HR-100TM?
Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
Mar 02, 2011 | Casio HR-100TMPlus Calculator
Letratag showing tape jam. Have changed batteries and tape roll
there's a paper jam inside the mechanism of thermal label printer, if you can do open it, clean it also, just be careful to put it again.
Feb 12, 2011 | Dymo LetraTAG Thermal Label Printer
VHS Video Tape - Picture Roll.
Picture roll is caused by the frame rate being out of sync with the play back device. If the tape was recorded at say 25 f/m and is being played back at 26f/m. If you can, adjust the frame rate until the picture stands still.
Mar 30, 2010 | Philips VRX242AT VCR
Rolling video screen
Is this rolling only in the viewfinder? or is it also on the tape? I suspect it is in the viewfinder only. If so, there are a couple of surface mounted capacitors that are out of spec and need to be changed. Parts cost less than $5.
Dan
Mar 17, 2009 | Sony Handycam DCR-TRV260 Digital Camcorder
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
23 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
