Question about Kitchen Appliances - Others
Where can I get a replacement element for a ZIP301 Clear Boil Kettle
jerryg50
  • 1689 Answers
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Posted on Apr 29, 2008
SOURCE: light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Posted on Feb 21, 2009
homemender
  • 158 Answers
SOURCE: When filled with water & put on to boil it
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Posted on Dec 23, 2010
  • 6771 Answers
SOURCE: I recently returned my two
No! you have clearly a manufacture defect or a design issue, I would take it back and select a different brand if possible or your money back.
Posted on Mar 19, 2011
  • 5 Answers
SOURCE: My kettle lights up but does not boil the water
Element has gone
Posted on Apr 25, 2011
Information to question already asked the fact the power is lighting both lights up but no noise of starting to boil does this kettle need a new element and if so where can a get it fixed.
You are not specifying what make it is but you hardly get replacement elements for kettles any more. The fact that you can see that power is available at the kettle it is indicating that it might be the element being defective. Had it been it switched on without any water in it? If it is the old type where the electrical cord gets plug in at the kettle check if it is well plugged in otherwise it is time for a new kettle.
Apr 09, 2015 | Kitchen Appliances - Others
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
My kettle suddenly stopped working, it still shows a red light when you go to boil the water but the water does not boil. its only a few months old so what would cause this problem
sounds as if you have a lose wire in the base or else you element has failed. Undo the bottom of the kettle and check all wires are connected to the element. If all the wires are connect i would say your element has blown.
Apr 18, 2011 | DeLonghi KBO3001 Cordless Electric Kettle
I bought the Russell Hobbs Whisper Kettle expecting it to boil quietly. Wrong. It is quite the opposite. Not sure if I can take it back due to "false advertising"??
Have you tried descaling the kettle? When scale builds up over the whisper quiet element, it reduces the effectiveness, and the kettle becomes noisy. Try 1 tablespoon of citric acid, fill the kettle to the max line, boil the kettle then leave for 10 minutes. Rinse and repeat if necessary.
Feb 23, 2011 | Russell Hobbs RHOK3123 Cordless Electric...
My Phillips kettle does not boil water but the light turns pOn. It is electric
Very simply, it sounds like the element has blown. If the element is built into the base of the kettle I am afraid it is terminal, if it is a calrod type element that you can see in the kettle, it can be replaced.
Jan 21, 2011 | Philips Kitchen Appliances - Others
The power switch light on my kettle comes on but it wont boil
1. Check the continuity on the power switch
2. Check to see if any thermal cut-out is open circuit
3. Check to see if the element has gone open circuit.
Any open circuit indicates the part will require replacing. Given the cost of the kettle, if the element has gone open circuit it may be worth considering replacing the kettle itself.
Mar 25, 2010 | Russell Hobbs RHOK3123 Cordless Electric...
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Kitchen Appliances - Others Logo
26 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
