Question about TORK Hardware & Accessories
I have a Tork timer 1101 that only works every other day.
SRF518
  • 232 Answers
SOURCE: I need an instruction manual for the Tork 1101
go here:
http://www.weisd.com/store2/TOR1101.php
click on the wiring diagram
Posted on Oct 14, 2009
SOURCE: I have a Tork timer model number 1101 24 hr time
Tork 1101 is a 120V mechanical dial-type timer
c79f9b8.jpgTork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
Posted on Oct 15, 2010
gotgeek2
  • 565 Answers
SOURCE: I have a tork 1101
This is for 120 volts ONLY. The incoming "main" black wire from the circuit breaker or source connects to terminal 1. Leave the bridge in place between L and 1. The outgoing black wire to the load connects to terminal 2. Both white wires connect to x.
Posted on Nov 11, 2010
SOURCE: I have a Tork 1101.
Tork 1101 is 24-hour 120Volt mechanical dial timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
http://www.frontierlighting.com/product.jsp?part=3495&process=search&show=&
Make sure these trippers match yours before ordering
Posted on Dec 10, 2010
SOURCE: I have a 15 yr old tork 1101 pool timer. I
1) Tork P47 tripper is correct tripper for 1101 timer.
Trippers are brass-colored and black-colored.
If they do not fit timer dial you might need new timer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
2) Buy new 120Volt indoor/non-weathertight Tork T1011
To identify timer for sure:
3) Google search Tork 1101 shows timer cost $83
4) Intermatic cross reference shows replacement is T-101 indoor/non-weathertight
Amaxon sells T101 for 43$:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
5) Raintight/outdoor: Aplus and Lowes sell raintight outdoor T-101R for $71
http://www.lowes.com/pd_29405-251-T101RD89_0_
http://www.aplussupply.com/intermatic/timer.htm
6) Cross over wiring.
Tork terminal X is T101 terminal A
Tork terminal 1&L are T101 terminal 1
Tork terminal 2 is T101 terminal 2
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 23, 2011
TORK 1101 Timer will not keep proper time?
Clean up the timer with compressed air and WD40.
If problem persists, then bad #101 120 volt clock motor probably
http://www.amazon.com/dp/B00AQZ78TU/?tag=waterheaterti-20
Clock motors and trippers can be replaced on Tork series timers.
Gene
Oct 27, 2014 | Hardware & Accessories
Can a tork timer 1101 be used to control a 240 volt pool pump motor by controlling only 1 lead of the motor thus having the other lead hot all the time?
Yes: 240 volt can be controlled by turning off 1 hot leg of 240V circuit.
But the tork 101 clock motor still requires 120Volts (unless you buy a tork 240volt 201 clock motor to replace the 120volt 101)
Copy following links for handy resource and wiring diagram:
http://waterheatertimer.org/images/Tork-1101-wired-to-control-240.jpg
In the wiring diagram above, it shows white neutral wire running to Tork 1101 timer terminal 2. Bring this white neutral wire from any nearby 120volt outlet.
In event that you do not have this white neutral wire, you can connect ground wire to terminal 2 and that will give 120volts to the 101 clock motor.
Completing circuit to clock motor using ground wire is violation of national electric code for many reasons, however the tiny clock motor only draws 3 watts, and you will remember to bring a white neutral wire to this timer at later date so you can sleep better at night.
Additional resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
Aug 27, 2013 | Hardware & Accessories
How can onr tell if timer on Tork 1101 is not working?
Is the dial rotating?
1) Copy following link for Tork 1101 product wiring and manuals:
2) Tork 1101 120Volt timer uses #101 clock motor.
If clock motor is working, then dial rotates around clockwise once each 24 hours... assuming timer is wired correctly.
3) Jan 2013, Add a comment and say what you are wiring.
Jan 30, 2013 | Hardware & Accessories
I have a tork 1101 and i want to conect a sumersible pump 1 hp 230 v single phase but i dont know how can you help me.
Tork 1101 has 120Volt clock motor.
So circuit needs a neutral wire, in addition to 240Volt circuit with 2 hot wires.
Make sure brass bridge or jumper wire connects terminals L and 1.
Open following link for illustration.
Resources:
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Aug 30, 2011 | TORK Hardware & Accessories
I have a Tork 1101 timer and up until now has worked fine. Now it won't shut off. The mechanical on/off tabs are set correctly. It turns on and as the timing wheel comes around, the shut off tab...
If clock is rotating on time, next suspect is P47 trippers have worn down. Trippers are made of softer metal so they wear down instead wearing down the on-off lever, and that way the timer lasts longer.
New replacement Tork 1101 120Volt timer can be purchased on-line at Amazon etc.
Home Depot sells the 120V GE 15306 indoor-outdoor version of Tork 1101 timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Replacement timer in Intermatic is T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jul 24, 2011 | Kitchen Ranges
My Tork 1101 24 hr timer has stopped working. I hear it running, but the clock will not turn. I have to turn it on and off manually for my pool pump. This happened 2 years ago, then the following year...
You might need $45 clock motor for for Tork 1101 120Volt.
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Open following link to identify timer and see replacement clock motor and trippers:
Intermatic crossover shows T101 timer replaces 120Volt Tork 1101.
Amazon sells new Intermatic timer for $45 with super shipping
Crossover wiring from Tork to Intermatic:
Black wire on Tork L and 1 connect to Intermatic terminal 1
White wires on Tork X connect to Intermatic terminal A
Black wire on Tork 2 connects to Intermatic terminal 2
http://waterheatertimer.org/How-to-wire-T104-Intermatuic-timer.html#T101
Add a comment for more help
Upvote the help.
Jun 04, 2011 | Vacuums
I have a Tork 1101. Please advise how to set the OFF time.
Dec 09, 2010 | TORK Hardware & Accessories
I have a Tork timer model number 1101 24 hr time switch. Can you tell me how to set it???
Oct 14, 2010 | TORK 651A Photocell Controlled Mechanical...
I have a Tork 1101. I am confused by wiring diagram. Please help.
1) Tork 1101 has 120Volt clock motor, making this 120Volt timer.
2) 120Volt circuit has 1 black hot wire and 1 white neutral wire and 1 bare ground wire. Ground wires connect to green screw and to each other.
3) You have two cables, each cable has black, white and ground.
One cable arrives from breaker box.
One cable goes to Load (light, fan, motor, pump etc)
4) Cable arriving from breaker box:
a) Hot black connects to terminal L.
There should be a brass connector plate that connects terminals L and 1. If this plate is removed, then add a jumper wire from terminal L to terminal 1.
b) white connects to terminal X
5) Cable going to Load
a) Load black connects to terminal 2
b) Load white connects to terminal X along with other white wire.
Aug 20, 2010 | TORK Variable Cycling Timer 8601
I have a 15 yr old tork 1101 pool timer. I misplaced the tripper pins the replacements P-47 dont fit. What do I do
Jul 11, 2010 | TORK Digital Interval Timer Ssa100r-24
Hardware & Accessories Logo
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
