Question about Dyson Vacuums
How do I replace the top handle? It's the one that says DYSON at the very top.
Hi i have a dyson dc 28. How do i recline it also the suckson i at the top of e handle where the red flap is. PLEASE HELP!!!
Put your foot on the indentation on the side of the head and tilt the handle backwards.
The suction from the flap on the end of the handle will stop when it reclines. That function is to allow the use of the hose with the cleaner in the upright position.
dyson dc28 manual Google Search
Oct 05, 2017 | Dyson Vacuums
Dyson wand, handle and hose are all unattached. How do I put them back together?
You can find a copy of the DC14 Manual here (
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/dc14_opmanual_usa2007%20pdf.pdf ) Pages 4, 5, and 6 have plenty of schematics for putting the wand/handle assembly back together and getting everything to click. In a nutshell, the metal tube pretty much just slides back into the tube top, and then the slid-in tube clicks back into the top of the machine.
Good Luck!
Jul 12, 2014 | Dyson DC14 All floors Bagless Upright...
Dyson dc25 handle stuck at top of wand wont relaese
Hi there, it's Jack at Dyson.
A jammed DC25 wand may mean that the hose was twisted when the wand was last replaced on the machine. This can prevent the wand from extending or retracting fully. The video I've attached shows you the simplest way to resolve this.
If you would like any further advice from our experts, you can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 22, 2014 | Dyson DC25 All Floors Bagless Upright...
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting www.dyson.com and clicking 'Support'.
Kind regards,
Jack
Dyson Online Customer Support
Aug 28, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson animal 25 wand won't go into tube
We have a DC65 Animal, the extension tube on the hose would not slide into the top of the handle.
The solution:
1. Slide the hose into the cradle on the handle
2. Push the tube down close to its stowed position
3. Near the bottom of the hose, gently push the hose against the handle with one hand and then push the tube down with your other hand
4. Close the cap on the top of the handle
Feb 02, 2011 | Dyson DC25 Animal Bagless Upright Vacuum
I have a dyson dc07 bagless vacuum cleaner. How do I split the top and bottom halves of the dust collection bin? There is a lever and catch on the side, I have tried pulling and turning, but with no...
Hi at the top of the Cyclone there is a lever underneath the Handle. The Handle I am referring to says Dyson on it. Firstly you must release the Cyclone from the spine. After doing this you will be left with the Cyclone and the Cyclone Bin all in a oner.
To empty the bin you must lift the lever which is underneath the Dyson handle.
You can only seperate the bin from the cyclone whilst the bin flap is open.
Once you have opened the bin flap using the lever you can then use the lever and catch to seperate the 2 items.
Oct 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
Hi its Darran at Dyson.
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I open my dyson cylinder
If you are referring to the cyclone top and bin assembly, once removed from the machine, there is a button at the base of the handle that has Dyson written on it that you press and pull the cyclone top and bin apart to empty it.
If you need any further help or advice, please try the Support section on our website at www.dyson.com.
Kind regards
Darran
Jan 09, 2010 | Dyson DC08 Cylinder Bagless Canister...
The suction in the hose of my 2 year old Dyson Animal vacuum is compromised. I may have sucked up a small cat toy or something. Regular vac still is fine. The hose "sucks closed" after a few seconds near...
Hi there, it sounds as though the wand handle is blocked. To test this, remove the wand handle from the hose and test the suction at the top of the hose. If its strong here, then you will need to remove the blockage from the wand handle. If the suction is still poor, you will need to remove the hose by pressing in the catch on the hose cuff near the base of the machine and removing any blockages.
I hope that this information is useful to you.
Kind regards
Darran
Dec 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
