Question about Kenmore Cooktops
How do I unlock the cooktop on kenmore c970-440994 displaying PF?
How do I unlock it
Maybe these steps will help. It would be better if we knew the brand and model but here's my fix for my kenmore
I had to look this up as well:
To unlock the cooktop:
1. Turn all burners to the OFF position.
2, Press and hold the TOP keypad for 5 seconds.
You will hear a single tone and lock off will disappear from the display.
Jan 17, 2015 | Cooktops
Kitchaid electric range display PF what to do
PF indicates a Power Failure. Turn off the power supply (for 30 seconds or more) to the unit and then back on, select/touch the range cancel/clear pad and reset the clock. The range should work again, unless there was damage to the control during the power interruption.
Oct 05, 2014 | KitchenAid KERS807SSS - Freestanding...
Red light on stove surface is lite up red and code pf is on display
"PF" displayed on the control:
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Apr 04, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    My Kenmore Range had theoven and stovetop locked symbol on it how do i unlock it
    Either hold down the 'Unlock' button or if the little red pad lock symbol is lid in the main display hold the 'Oven light' button for about 7 seconds...
    Jan 18, 2010 | Kenmore Elite 44173 30 in. Electric...
    Whirlpool Cooktop will not reset
    Well the solution was to unplug the 220Volt connection for one minute--plug it back in--reset the clock, hit start and bingo it worked. I found on the back of the stove the technicians schematic, and error codes in a plastic envelope that described the procedure for finding--isolating--and solving the issue by the use of the error codes, which were not avaialable online anywhere but in the diagram and description for a technician's use.
    I saved myself $109 dollars by avoiding the call out, but still my breakfast was four hours late!
    Dec 27, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
    Kenmore 44083 Cooktop
    should be an unlock button.....press and hold the button until it unlocks
    Apr 05, 2008 | Kenmore 30 in.44084 / 44089 Electric...
    Cannot turn on cooktop.
    I have a Kenmore Elite Induction Cooktop and we had some milk boil over and now the cooktop is locked. How do you unlock it?
    Aug 30, 2007 | Smeg 24 in. SE2663TC Electric Cooktop
    Cooktops Logo
    131 people viewed this question
    Top Kenmore Cooktops Experts
    Dan Webster
    Dan Webster
    jdthefixer
    mcgsp
    Level 1 Expert
    Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
