Question about Dyson Vacuums
I finally found a part for my Dyson DC15 that I need only I'm not sure how to replace it with the new one. It's the top handle that has "DYSON" in big letters.
SOURCE: Dyson dc15 ball/ taking apart
The Dyson site has a help section where you can read how to take the unit apart to unblock it. Maybe your solution can be found there.
Hard to tell since you didn't say what the part is.
Posted on Oct 30, 2008
chrispurs1
  • 372 Answers
SOURCE: Changing the main hose on a Dyson DC15 Animal
Hi Bob.
If you look carefully where hose & elbow jount enter machine you will see a slot.
Rotate elbow so that lug on elbow aligns with slot & pull off.
http://dysonmanuals.llc.nu
Posted on Jan 14, 2009
  • 389 Answers
SOURCE: I need basic instructions on how to operate a Dyson.
Copies of Dyson Operator Manuals are accessible on the Dyson website.  You will find everything you need there!
Posted on Feb 07, 2009
SOURCE: DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Posted on Jun 01, 2009
  • 83 Answers
SOURCE: how do i adjust the brush height on my dyson dc15
The brushbar pivots, you can't manually set the height of it. It moves along with the contour of the carpet or floor that you are vacuuming.
Posted on Jul 30, 2009
When vaccum is tilted back suction does not engage.
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Once covers are removed check both yellow and blue wires carefully. Wires may look intact but the break may occur inside the black grommet. Slowly and carefully push grommet out and then carefully pull wires to the one side. If a wire is loose or broken you will immediately see the break. You can replace wires using replacement part given below or if you are OK with using soldering iron you may be able to repair broken wires without any expense.
Best solution is to replace broken wires with a new set of wires and connectors having fed the wires through the access hole making sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
  • UK: Dyson DC15 Loom BB Over Current, Part No: 907280-03, Approx. Pounds 4.45
  • US: Dyson DC15 PCB to Yoke Loom, Part No: 907280-02, Approx. $11.75
See more details and photos at: http://bajwa.net/content/dyson-dc15
Feb 20, 2013 | Dyson DC15 All Floors - The Ball Bagless...
Where is the plunger located on a Dyson DC15 all floor model
I'm not sure which part of your DC15 All Floors you're describing, but if you take a look at our Support page for this model, you should be able to find the information you're looking for:
http://www.dyson.co.uk/support/dc15/dc15-the-ball-all-floors
You can also download a copy of the user guide for this machine here:
http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc15_uk_manual_120710 pdf.ashx
I hope this helps - if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 12, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Fixing seal on dyson dc15
I'm not sure from your question which seal you're trying to replace on your DC15. For assistance, please get in touch with us directly by calling free on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Jan 08, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Where is the upright switch located on a dyson dc15 all floors thanks
Hi John,
I'm not sure from your question exactly which switch you're referring to on the DC15. However, you should be able to find an answer on our online support guide for this machine:
http://www.dyson.com/support/help.asp?article=527&product=DC15-SY-STD
You can also download a copy of the DC15 user guide, in case you don't have yours to hand:
http://media.dyson.com/downloads/us/floorcare/manuals/dc15_opmanual_usa.pdf
I hope this helps - if you'd like any further assistance or advice, please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Oct 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
The wand handle is jammed in my dyson ball
Sorry to hear you're having difficulties with your Dyson DC15. It's probably best if you get in touch with us directly so one of our experts can talk you through the process of releasing the jammed wand. You can call us free on 08002980298 (UK), or 1866MYDYSON. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 04, 2011 | Dyson DC15 All Floors - The Ball Bagless...
My Dyson DC15 has stopped working. the brush bar is fine and rotates freely. The motor inside the ball has stopped working. Do I need a new motor or cicuit board. I'm an electrician so I can handle the...
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
Check the above link to see if it helps. It shows you how to break down the DC15 to check for issues. Also try inspecting the circuit board for loose wires.
Lastly, can try calling their helpline at 866-MyDyson for further help.
Aug 03, 2010 | Dyson DC15 All Floors - The Ball Bagless...
I need a vacuum brush housing assembly for Dyson DC15 animal. Part of it is broken (plastic).
http://www.espares.co.uk/dyson/dc15/p/1086/716/10
Try the above link or do a search in google for "Dyson DC15 parts". Also, try searching in Ebay. You should have no problem in locating the part. Lastly, try calling Dyson at 866-MyDyson.
Good luck.
Aug 10, 2009 | Dyson DC15 Animal Bagless Upright Cyclonic...
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Oct 15, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
