Question about Bosch Dryers
How to remove front panel on Bosch wtl 5410 dryer?
  • 36 Answers
SOURCE: Dryer drum will not turn
sounds like a power promblem to me check at out let for 220 volts if you have it there first turn circete breaker off then on try drier if that dont get it check for power at outlet with meter if 220 is there after unplugging drier check cord at back of drier at terminal block if all thats ok then you have a bad door switch a bad start switch or a bad thermal limiter last and rare bad drive motor
Posted on Dec 29, 2007
  • 228 Answers
SOURCE: Re-set button location?
you need to remove the back panel the smaller one that covers heater matrix you will find a thermostat with a red reset button on it when you push it it will click and reset however you should find out why this happened before you use it again as it only does this if it overheats.
hope this helps
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: broken door closer/holder on Bosch Axxis WTL 5410
i've found the part (door hook) on https://www.repairclinic.com/
Posted on Jan 16, 2010
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
  • 101 Answers
SOURCE: where EXACTLY is the reset button on the bosch wtl
sometimes, it's behind the panel where all your switches, etc. are - in the top front of your machine. First, disconnect the cord from the electrical outlet before you do this, or at least turn off the circuit breaker.
Posted on Mar 13, 2010
My dryer WTL 5410 electric condensation dryer is cutting on and off.
this is normal operation it turns the drum one direction then the other this is because of the way it condensates
Apr 06, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Where is reset button?
Remove the panel in the back of the dryer that covers the heating element. ( the inner panel) (part that sticks out). Once that panel is off you will now be able to see the heating element and the thermal sensor. the reset button is located on the thermal sensor.
Dec 11, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Where EXACTLY is the reset button on the bosch wtl 5410? behind the lima bean panel? in the little white box upper left? where EXACTLY is this frigging switch?
Mar 13, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
hope this helps
Jun 29, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Load capacity of WTL 5410
7 kg is the max this is quoted as dry load not wet halfed when wet.
May 30, 2009 | Bosch Axxis WTL 5410 Electric Dryer
How to un-stack Bosh Washer WFL 2060/Dryer WTL 5410
Did you ever get an answer? I have the same problem...
Mar 21, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
