Question about The Health & Beauty
I need to order the arm cuff for model 1086CVS
    New Friend:
    Problem Solver:
  • 18 Answers
What you show is a model number for a B/P cuff that is not one
shown for CVS. You also do not mention a size for the needed cuff.
Cuffs come in different sizes from Infant, Pediatric, Small Adult, Adult, Large Adult, Thigh.
CVS, and all the different manufacturers sell cuffs to fit monitors. Only the size of the cuff needed matters, and possibly the end fitting if something more is used other than just the rubber hose.
Look up any online company, or your local pharmacy and look for the replacement cuffs for monitors.
Posted on Apr 20, 2017
I'm looking for an extra large arm cuff for an automatic arm blood pressure monitor model WGN BPA-530. I have been working out and arm is now 15. Thanks for your help Eric in Fresno Ca.
as you will notice that there is now a blood pressure machine that clips around your wrist
try wrapping the cuff around your wrist or lower arm
Nov 12, 2017 | Health & Beauty
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
Why does anOmron M7 Blood Pressure Monitor Cuff not fully inflate?
I have the BP760 model so I'm not entirely sure what the functionality differences would be. However from time to time I have had issues with the cuff not inflating. It is usually one of two things: the cuff is not positioned snugly enough on the arm (I have a skinny arm and sometimes need to enlist the help of a family member). The other time it has happened was when the inflation tube itself with so kinked and twisted that air could not flow through. You should also check to make sure that the inflation tube in securely connected to the unit. So make sure that the air supply from the cuff to the unit is not obstructed, and that the arm cuff is positioned properly and that you are not trying to put the cuff on over clothing. If you've checked all of this and/or you receive the error message of "Er", you should contact customer service. Hope this helps.
Aug 29, 2014 | Health & Beauty
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
Jan 22, 2012 | Health & Beauty
Omron- HEM712C- why does the\r\ncuff opens,when trying to take pressure.
It's likely due to either improperly seating the cuff over your arm, or the cuff being sized to small for the circumference of your arm. First make sure that the cuff is set up properly, the "hook" end of the velcro needs to be facing away from your arm. Once you double the cuff back, make sure that it is not so tight as to be cutting off circulation. If this occurs the force of inflation will cause the velcro to separate. It's also possible that the package included to small of a cuff. If so the manufactor has a largercuff here.
Mar 13, 2011 | Omron Healthcare Omron Hem-712c Automatic...
How do you measure the arm to find out the size of cuff you need? My mother is small, 95 years old and I'm not sure if this cuff that comes with this machine will be too big or not. I don't want to buy...
hi, the part of the arm the cuff goes round is the upper part it goes over the muscle at the top of the arm, if you start at the shoulder and go about to hands witdths down the arm this is where the cuff goes around, hope this is some help to you, if your unsure give me a shout back
Aug 18, 2010 | Mabis 04-595-001 Talking Blood Pressure...
Looking for replacement arm cuff for my sunbeam blood pressure monitor model 7652
To get a replacement arm cuff call sunbeam at 1-800-394-2326
The cuff will cost you 12.95 there. If you need you can get the manual and order sheat on the link below. Page 10 of manual.
Good Luck
May 24, 2010 | Sunbeam Health & Beauty
Cuff position
An upper arm monitor will come with a cuff that you need to wrap around your arm. If you use a cuff that is the wrong size for you, your reading will not be correct. Measure around your upper arm at the midpoint between your shoulder and elbow. Most monitors will come with a medium sized cuff. You may have to order a different sized cuff separately.
Aug 27, 2008 | Haba MDF Thigh Single Tube Latex Free...
Health & Beauty Logo
49 people viewed this question
Top The Health & Beauty Experts
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
