Question about Consew Sewing Machines
Consew machine. My bottom thread has ball knots on the bottom. I have changed the needle and the top stitch is perfect. Please advise.
  • Consew Master
  • 10,284 Answers
Re-check the thread that is knotted. It's most likely the top thread causing what is called thread nesting or what I term "thread barfs."
Thread problems appearing on the top of the fabric are generally caused by the bobbin thread. Problems appearing under the fabric are usually a result of upper thread issues.
Remove the top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the upper tension to the midway point.
http://www.superiorthreads.com/blog/2015/8/what-causes-bird-nests/
Posted on Apr 19, 2017
How do i adjust my consew 105 so the stitches do not loop on the bottom?
If the thread is looping under the fabric, it is a top tension issue.
Make sure you are using a new needle and that the needle/thread/fabric are compatible.
Verify it is threaded correctly and that the thread is firmly seated in the tension disks.
If the top thread is still looping under the fabric, then the upper tension is too loose.
Nov 07, 2016 | Consew Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Feb 06, 2016 | Consew Sewing Machines
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Uneven bottom stitches that ball up every 4th or 5th stitch
Have you threaded the bobbin correctly? If it is in the wrong way it will do that. Hope this helps.
Mar 08, 2010 | Sewing Machines
Skipping stitches and knotting up underneath.
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Sewing Machines Logo
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
