Question about Ovens
Brand new Bush built in oven type BSOBFW digital clock turns off when the functions knob is rotated.
SOURCE: Oven Light won't shut off
Amazing, I had the same problem, was told the same thing, even quoted the same amount!   There must be a playbook with stupid answers by repair people.  Anyhow, here is how I unlocked my oven:  "Press and hold the 'Lock' button for 3 seconds then let go and it should unlock in about a minute."  Hope this works for you. Don
Posted on Feb 05, 2008
SOURCE: Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Posted on Jun 28, 2008
barkencoa
  • 3463 Answers
SOURCE: my bs32 built in hotpoint oven knob is seizing
If you can pull the knob off spray wd-40 into the aperture where the switch is.and try it again,if no better, then you will probably need a new switch.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
erpaalai
  • 999 Answers
SOURCE: Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Posted on Jun 21, 2009
  • 3 Answers
SOURCE: 9yr old smeg 60cm wide electric wall oven,
this could well be the cooling fan pin bearing that is failing
Posted on Jul 08, 2009
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
1965 Moffat Electric Built-in oven - model #21K90. No manual and no information on any of the websites I've searched. There is power (oven light, warmer light, rotisserie, power rack), but clock and...
My father solved this one, those clocks were such a hassle, ours buzzed for days til he fixed it. It requires opening the control panel and bypassing the wiring that allows the clock to turn the oven on and off. Of course you lose this function. Is that the complete model number?
Oct 26, 2013 | Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
My oven is brand new, id tried it earlier, but its not functioning, how can i operate my la germania oven
CHECK the POWER CONNECTION PROPERLY. IF IT IS ANALOG TYPE OF OVEN TURN AROUND YOUR TIMER KNOB.
Aug 06, 2011 | Ovens
Can you tell me how to turn on a tecno fan forced oven? It has been turned off by power interuption and now the clock is flashing with 0.00 and 1 and Auto? Please help.... thanks
most digital clocks have several buttons underneath them they are usually set by pressing 2 of the buttons at the same time and then the up down button for the time sometimes the up down setting is done by rotating a knob you will know when you have chosen the correct buttons the numbers will stop flashing failing that relist your problem with a model name and number if you can find one
May 29, 2011 | Ovens
Oven won't work beacuse of the timer on the stove.
It depends on the make and model and wether it is a digital clock.
But generally if you press/turn the larger knob this will reset the clock and return the oven to manual cooking .
Jan 01, 2010 | Ovens
How do you set the analog clock?
My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
Oct 20, 2009 | Viking 27" Professional Select Built-in...
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Jun 26, 2008 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
