Question about Whirlpool Washing Machines
I have whirlpool washer model wtw6600sw0 with code 5d I do not know where the drain filter pump is?
  • Official Brand Answer
  • 345 Answers
Thomas, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Thomas), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Posted on Apr 25, 2017
5d error code
It may have F21 code together meaning long drain in the system. Open the small top toe part then will see the pump. Open the filter and clean the pump.
Oct 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Error code 5d or f-21
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 16, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a WTW6400SW2. Always get 5d code if we use high spin speed or do large load. Also seems to take forever for tub to drain. Related problems? In the past have epoxied exterior of drain pump due to...
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The machine start to work ,but then i can see 5d and i don't know what it means
Hi
Daniel
Aug 10, 2011 | Kenmore Washing Machines
5d error code
Hi
Daniel
Aug 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi i have a Whirlpool sport duet and after a few minutes it stops going and Sd or 5d comes out on the small screen. What does this mean? Does not say in the owners manuel
Hi
Daniel
Aug 04, 2011 | Washing Machines
I have a whirlpool- cabrio and 5D or SD error code appears. What is the problem and how do you fix it.?
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jul 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Problem draining. Getting 5d code.
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
8. Verify CCU operation by running a Diagnostic Test.
Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
