Question about Car Audio & Video
The aux input is only outputing sound on right speaker with my ipod. tried ipod in different car works fine.thanks
  • 1,596 Answers
Sounds as if the LEFT Channel of OUTPUT IS Burned out this Happens MORE With Children Around to Plug Inapropreate Things into it
Posted on Jul 24, 2009
My zeppelin has stopped playing altogether, ipod works fine, but no sound ... yes i have turned it up!
if the aux input at the rear works, then the fault relates to the docking arm or the interface on the back. (Does the ipod charge on the docking arm, have you tried another type of ipod, as different ipods have different connections through the arm!)
if the aux input does not work, then the main board/amp/pse could be an issue.
if the model is more than six months old it will probable have the known problem boards, so contact b and w servie and they should check it out.
Mar 02, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
I hooked up the ion LP Dock to an analogue amplifier (which is hooked up to my LCD tv and outputs the sound through some bookshelf speakers) via the Phono input connections as per the instruction manual...
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
BUT, modern turntables like your come with their own preamplifiers, so they MUST be connected to a garden variety Line Level input like AUX (anything BUT Phono or it will overload).
http://www.needledoctor.com/Ion-LP-Dock-Turntable?sc=7&category=16189
"LP DOCK also has a line-level output for connecting to any home stereo with an AUX input"
As far as WHY your amplifier isn't making da music, that could be whole 'nother problem.
We'd need more details about it and the speakers to go there.
Feb 27, 2011 | Universal Electronics Ion LPDOCK USB...
My daughter has an Iwantit ipod speaker model IW900 and it works/sounds fine with her ipod usind the dedicated ipod connector. On the the back of the speaker there is an Aux in socket. She would like...
It took me a while to figure this one out. Firstly plug your device in to the aux socket and play some music so you can hear when it's correctly switched over. Turn on the iwantit using the switch at the back then press the play button once, you should see the lights on the buttons go brighter. Now press the play button again, this time holding it down for exactly 3 seconds. When you release the button you should be in aux mode and you should hear your music playing. Hope this helps, it took me about an hour of faffing around before I finally figured it out.
Aug 16, 2010 | Audio Players & Recorders
I want to connect my ipod to the aux inputs on back of unit
Hello gcd_sun,
The RCA jacks on the back of the Pioneer DEH-1500 are preamp outputs, not inputs. They are to connect an external amplifier for additional speakers or subwoofers.
The output from your iPod is probably "bleeding over" into the receiver detector stage. When the antenna is disconnected, the signal passes into the amp by itself. Connecting the antenna provides enough signal so that both are amplified.
To connect the iPod, you need to purchase a wireless iPod adapter, or a new head unit that includes an "AUX" input or a dedicated adapter for the iPod.
Hope this helps.
Sep 10, 2009 | Pioneer DEH-1500 CD Player
Working fine, then no sound coming from speaker whilst working on auxilliary connection to TV
the aux connection uses different connection on the rear interface, if this has never worked then it may be a compatability problem, if it has, then there is a failure on the rear input (aux). contact b and w service or supplier, they should repair and also update your power supply board.
Sep 09, 2009 | B&W Bowers and Wilkins Zeppelin iPod Music...
Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Jul 05, 2009 | Alpine CDA-9827 CD Player
Aux in runs only back speakers and no volume control
check sub setting some radios can select between non fading sub output or aux input
May 08, 2009 | Pioneer DEH-P3000 CD Player
Barely hear music from ipod when connected in aux Alpine CDA9835
Turn Vol up on i-pod.Go to full,then back a bit. Good luck!
Mar 13, 2009 | Alpine CDA-9833 CD Player
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
