Question about HP PSC 2410 All-In-One InkJet Printer
Both ink cartridges have recently been changed and yet when you print the paper comes out without a spot of ink on it. I tried to print several more times and finally got a little bit of ink on the page, but very little, not enough to actually be able to read it. What's wrong?
  • Matthew Boulden May 11, 2010
    I know it may sound obvious, but did you remove the protective tab from the new cartridges?
    Master:
  • 409 Answers
Did you remove the transport tape from the nozzles of the new ink cartridges?
Posted on Jul 24, 2009
Lexmark 730 not printing
Regarding the Lex1 cartridge's no printing/severe fade (or similar) during printing, my answers are provided below:
For the poor print quality problem (degraded image quality) you are observing, we suggest you first visit the "Print Quality" page of the "General Information" section of the Inkjet 411 website and follow the suggestions provided: http://inkjet411.com/?page_id=1432
A. 1. Cartridge & Printer maintenance should also be evaluated - ensure both ink cartridges and flexible driver contact cables (where the cartridge interfaces to the carriage inside the printer) are thoroughly clean: http://inkjet411.com/?page_id=1519
A.2. Perform a hot-water flush on the suspect ink cartridge, refer to video procedure here: http://inkjet411.com/?page_id=1519
A.3. Run a quick test print to evaluate cartridge performance (i.e. 4-color test print):
http://inkjet411.com/?page_id=146
For information on North American ink refill services (for Lexmark 1, 2 and 3 ink cartridges) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced Lexmark printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 16, 2013 | Lexmark Office Equipment & Supplies
Prints with ink marks on paper
I would suggest you replace the photoconductor unit ( Part #:12A8302)
Hope this helps!
May 16, 2012 | Lexmark E232 Laser Printer
My mx860 is printing fine for every ink cartridge except the big black one. it hardly prints the black ink at all - sometimes i just get a black page. this is recent - after a month of not using it. i...
Hold a piece of tissue under the ink jets and see if the tissue draws ink out of the cartridge. If not the cartridge is blocked or empty. If ink does come out there may be a faulty contact on the cartridge or printer. Try swap out the cartridge with a known working one and see if that works.
Jan 26, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
No ink output from Epson Stylus Color 777
I don't have an answer for you but I have the exact same problem.
I have an Epson Stylus Color 777 and I put in new cartridges (black and color) that I bought yesterday (03/05/10).
I pulled the tape off the cartridges and inserted them in their carriages. Everything works like usual except that no ink at all prints on the page. Comes out completely blank.
Nov 11, 2009 | Epson Stylus Color 777 InkJet Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Aug 17, 2009 | Brother Multi-Function Center MFC-240C...
Fresh ink appears on back of paper
the drum or toner cartridge appears to be corrupted..you have a warranty on this printer?
this link might be of some help to you
Feb 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Not printing
Try taking a paper towel, and spray it with Windex (with amonia).
Take the cartridge out, and wipe the bottom of the cartridge with it.
This will wipe away any dried ink on the print head.
Then if you take a dried piece of paper towel, and press down on the bottom of the cartridge by the heads for about 5 seconds, you should see a spot of ink.
If that doesnt help, then repeat the above steps and try it again.
Last resort, try a new cartridge.
Good luck.
Feb 08, 2008 | Canon BJC 2100 InkJet Printer
Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Dec 31, 2007 | Epson Stylus CX5000 InkJet Photo Printer
HP PSC 2410 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
