Question about Belkin Computers & Internet
How do you set up 2 Belkin web cams. It will only let me monitor 1 and won't even register that there are two.
    Master:
  • Belkin Master
  • 247 Answers
To speak Belkin technical support representative dial +1 (800) 204-4427 (U.S.) 6 Am to 6 Am, (24*7 hours) Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our tech support team 1-800- 204-4427, which is especially open round-the-clock for online assistance.
Posted on Apr 19, 2017
    Master:
  • 604 Answers
You can only use 1
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
James,
It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
How to Change the Screen Refresh Rate of Your Monitor
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Sep 18, 2013 | Dell Computers & Internet
How to connect my laptop wirelessly to the belkin router?
You may want to click to wireless network icon on the bottom part on the rght part of your monitor and search for network. Then you may want to chose your network and, if you chosed this option, to type the password for the network.
Let me know if you were successful in solving your problem
Mar 01, 2011 | Belkin Computers & Internet
Hi my name is Nargiz i have web cam chicony dc 2112 pabda 2a and i need the drivers
Okay sir, this is what you need to do to download the driver for your Chicony 2112 web cam.
1. Click this site, fill up forms and get registered.
2. Get log in.
3. Once log in, click this driver chicony 2112, then click DOWNLOAD
Please rate this answer. Thanks for using Fixya.
Aug 16, 2010 | Computers & Internet
Acer Crystal Eye Web Cam
Try to locate the camera driver and do a update also might be a fix download for the Crystal Eye Cam through Acer Or another download site. Another idea would be to get a driver Program which checks all your drivers on the main items like keyboard, web cam , mouse, monitor, graphics the one i use is DriverDetective works great!
Aug 22, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Digital cam as webcam
step 1 Check the manual of your digital camera to see if it can be used as a webcam. Many digital cameras have this functionality and even come with webcam software. If your camera didn't come with webcam software, use a third party web cam application such as SarmSoft WebCam. Find SarmSoft WebCam at ShareUp.com.
Step 2 Plug your digital camera's power adapter into the camera. Some won't function as a webcam unless they are plugged into A/C power. Even if your digital camera functions as a webcam while on batteries, A/C power saves your batteries and prevents your camera from shutting off in the middle of a broadcast.
Step 3 Connect a video cable into your digital camera's video "out" port. Your camera likely came with a cable made for connecting it to a to a video source. Plug the other end of the video cable into your video card's video "in" port.
Step 4 Set up your camera as close to your monitor as possible. This allows better face to face communication.
Step 5 Position yourself about 2 to 3 feet away from your digital camera. Most digital camera's focus best at this distance when used as a webcam.
Step 6 Use a separate microphone if your digital camera doesn't transmit sound when used as a webcam. Plug the microphone into the microphone jack of your sound card
Oct 21, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
