Question about HP Office Equipment & Supplies
How do I ascertain the IP address of a HP 3380 Printer?
  • johnny rebel Apr 19, 2017
    you don't ascertain the I.P. address of the printer because your printer IS NOT wireless,it requires use of a usb cord or a IEEE 1284-B parallel port.
    Master:
  • 604 Answers
Refer to your instruction manual
Posted on Apr 19, 2017
Testimonial: "The is nothing in the instruction manual and no option in the Menu. What then do I need to do?"
Why does my hp envy 5535 stops in middle of print job
Please try following the steps below and let me know if that may help:
  1. Open the HP Envy 5535 software, then click the Printer Home Page (EWS) link.
  2. Click the Network tab.
  3. Click Networking , and then click Network Address (IP) .
  4. Click Manual IP , and then click Suggest a Manual IP Address . A manual IP address, Subnet Mask, and Default Gateway displays.
  5. Be sure to take a note of the IP address and Confirm the changes, then close the EWS page.
  6. From the HP Envy 5535 sotfware click the Utilities tab, then click on Update IP Address.
  7. Type the manually configured IP address, click on Save and confirm.
  8. Open the control panel and go to Devices and Printers.
  9. Right click the HP Envy 5535 icon and select Printer Properties.
  10. Open the Ports tab.
  11. Click teh Add Port button, select Standard TCP/IP and click on New Port.
  12. Follow the steps by typing the manually configured IP address and confirm the changes.
Read More... HP Printer Support
Thanks,
Jul 23, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
We are hooked up to a network and I have recently had a new computer sent ot me. The Panasonic DP-2330 is no longer in our server. Our IT department is asking for the IP address for this device. How do I...
Download the owners manual for your machine:
http://ops.novacopy.com/usermanuals/Panasonic/DP2330_3030.pdf
Look at page 62, it shows how to access the IP address through the printer menu.
Jan 07, 2011 | Panasonic Workio DP-2330 Printer
How can i configure the IP for the printer HP laserJet P2015dn? what is the address that I can access this printer from my PC via web brower?
For configuring the IP address on the printer, you will have to browse the printer menu, and the IP or TCP/IP should be under Network. Here is basic information about troubleshooting network issues from HP website.
Once you have set up an IP address to your printer you will be able to connect from PC via the web browser by typing in the IP address of the printer.
Dec 15, 2010 | HP LaserJet P2015dn Printer
How can I change the baud rate on my HP Laserjet 3380?
There is no baud rate to this printer, it's either parallel cable or USB cable. Baud rate refers to the old serial cable connections, com1 or com2. You can add memory to this printer to make it print more documents faster. Try this location:
http://reviews.cnet.com/multifunction-devices/hp-laserjet-3380-all/4505-3181_7-30822993.html
May 11, 2010 | HP LaserJet 3380 All-In-One Printer
Installed hp laserjet 3380 on apple desktop pro - message printer stopped
See if it is the right driver. Intel Mac is not the same driver set as regular Mac.
Also, Apple + HP or Okidata often = issues.
Jan 12, 2008 | HP LaserJet 3380 All-In-One Printer
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
