Question about Philips Audio Players & Recorders
Philips FR 965 digital audio video surround receiver powers on and then goes into standby mode
    Top Expert:
  • Philips Master
  • 75,817 Answers
You may have a shorted speaker voice coil, disconnect the speakers and see if the amp stays on.
Posted on Apr 19, 2017
    Top Expert:
  • Philips Master
  • 34,170 Answers
The power supply may be failing.
5 Suggested Answers
SOURCE: philips digital audio/video surround receiver FR965/17
same here ,men , i start the tearing apart hehehe, and i think it can be one the little chip located behind the control panel so i remove the white ribbon, the one looking like an ide connector for a hard drive, and guess what it turns on, but when you connect the ribbon just goes back to stand by mode, maybe requires a flash on one of the little chips, same thing happen to a lap top that i use to have, just shorted 2 of the pins and start working normally, im gonna find more info but there sems to be nothing about this amp, high five from mexico men
Posted on Jul 08, 2008
robotek
  • 1512 Answers
SOURCE: where is the fuse on
Hi Hibbs8829
Generally fuses are located on the PCB attached to the power transformer terminations. In some instances the only primary fuse may be a thermal fuse located inside the power transformer that may have failed. This one you cannot see from the outside. They are replaceable, but you will need to get into the transformer somewhat to sort it out. Other than that, there are often fusible resistors and circuit protector devices on the PCB. These can be a little difficult to find if you don't know what you are looking for. Good luck
regards
robotek
Posted on Jul 15, 2008
SOURCE: Philips FR965/17 Digital Audio/Video Surround Receiver
http://www.p4c.philips.com/files/f/fr965dht/fr965dht_dfu_eng.pdf im pretty resourceful
Posted on Dec 18, 2008
hmerchant110
  • 7191 Answers
SOURCE: Where can I get an
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Kindly let me knnow if you have any difficulty in downloading the manual
Thanks for using FixYa.
Posted on Oct 06, 2010
What do i need and how do i connect my iphone to my phillips FR 968 so i can listen to music??
http://www.manualslib.com/manual/128395/Philips-Fr-968.html?page=11#manual
Looks like you need an audio splitter to Left/Right mini plugs.
Such a cable goes from the earphone output on your iPhone to the CD in plugs on the back.
Alternatively you could purchase a bluetooth converter, plug it into your digital input, and pair it with your iPhone.
Mar 22, 2015 | Philips Fr-968 Digital Audio/video...
How do I connect a Philips FR 965 digital
http://www.p4c.philips.com/files/f/fr965_00/fr965_00_dfu_nor.pdf Here ya go.
Oct 01, 2014 | Audio Players & Recorders
Trouble shooting problems
To reset the surround mode and other settings to factory default, hold down the VIDEO 1 button while the system is turned on and then press the STANDBY/ON button. "CLEAR" appears in the front display and the system will enter the standby state.
Sep 08, 2014 | Onkyo TX-SR600 Receiver
I think my receiver may have a blown fuse, when plugged in and I try to turn it on the red power light comes on and immediately shuts off, could this be a fuse problem?? If so how can i fix this
If your main power fuse was blown, there would be no power at all. You may be looking at a blown preamp or an overheated component inside your receiver. You may want to take it in to a service technician. Have you tried to contact Philips customer service?
Mar 30, 2014 | Philips"fr 975"receiver"digital...
Philips fr 965 wont stay on
It is shot, Kiss it good buy, Repair will be verry costly, Just go end get a different one, End not anouther (Phillips)
Nov 28, 2012 | Philips Fr965 Stereo Receivers
Does the phlips fr 965 have a fuse
If the unit was purchased in the UK, then yes it will have a fuse witht the following specs:
BS1362 5 amp, A.S.T.A or BSI approved type
Otherwise, I would suggest that you bring it to an authorized repair shop.
Feb 28, 2009 | Yamaha HTR-5730 Receiver
How to turn off standby mode
Try this:
On the top of your remote near the power buttons there are a series of buttons that have names under them such as "TV" and "DVD". Press and hold one of those buttons for about two seconds.
Jul 17, 2008 | Philips FR975 Receiver
Where is the fuse on a Philips FR 965 AV receiver
Hi Hibbs8829
regards
robotek
Jul 15, 2008 | Philips Audio Players & Recorders
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
No sound in surround modes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Aug 15, 2007 | Onkyo TX-SV525 Receiver
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
