Need help on fridge, stove and heater workings. They run off propane apparently, but I could really use an owners manual for 2005 springdale
  • Heating & Co... Master
  • 3,091 Answers
Google make and model number you should be able to download one off makersweb site
Posted on Apr 19, 2017
I have a 65, 000 BTU propane heater made by King Stove and Range about 40 or so years ago. Does anyone know where I can get a owners/repair manual for it? Works good but some things need working on
You might see if the manufactures still around you could call them, they might be able to supply you with one or otherwise the internets is your best bet.
Jan 05, 2015 | Heating & Cooling
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
My gas furnace fires but then cuts out. There is a similar post on here about this but my problem is a little diiferent. The unit kicks on, fires then shuts right down. The blower comes on and stays on....
HAD A similiar problem last week with a customer who had just installed a pool and running off of propane tank for gouse as well... he let tank go empty and started having problems ..what we ended up finding is that not only was his regulator on tank bad he needed a additional regulator to regulate the different psi pressure to the appliances... get them to check your regulator out
Jan 24, 2011 | Goodman Heating & Cooling
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Jan 05, 2010 | Desa International TB101 Heater
Top burners are propane. we are used to propane heating really fast. this stove seems really slow. 5minutes to boil litre of water. burners are having hard time lighting.
If it is new fromt the factory, you many have the natural gas (methane) jets in the burners. You will need to check your bag of parts to find the propane parts (LP parts). LP jets allow a different fuel/air mixture to burn at the right heat. Check the owner's manual for details how to make the change.
Please rate me - Good luck.
Nov 20, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Propane was turned off for unrelated problem propane turned back on stove will not lite
If your stove has a standing pilot, it will need to be re-lit.
If this does not help, state the model of your stove.
Apr 28, 2009 | Kitchen Ranges
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean .
All gas stoves are set up for natural gas. Before using on propane, the oven and burners need to be converted for propane operation. Refer to the installation manual for conversion requirements for your particular stove.
Dec 25, 2008 | Kitchen Ranges
Danby propane frig model DPR2260-2 owner's manual
I have the same refrigerator and am looking for the manual as well. Did you ever find one? If so, where?
Thanks,
Ari
Renata BC
hi_ari@yahoo.com
Oct 06, 2008 | Refrigerators
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
