Indesit 1060w leaking machine is 17 years old and performed faultlessly. But now it is leaking from underneath the machine when filling and draining. the leak appears to be from a black rubber gater underneath the drum that is part of the draining assembly/pump what is this? (its not directly connected to the waste pipe but has water running through it for sure)
  • Washing Mach... Master
  • 3,463 Answers
It sounds like the pump or the pump inlet/outlet hose is leaking, more likely to be the pump.
Please rate my solution.
thanks.
Posted on Jul 24, 2009
Indesit wa155 filling too full, also not draining fully
its the pressure switch or more likely the tube or pressure bottle is blocked, which is common.you need to check and clean this not too expensive to fix....
Jun 07, 2010 | Indesit WA 125 Front Load Washer
I have a 25 year washing machine that is leaking (not much) from underneath. all hoses are fine, drain too. It's the first problem i have had with it. Can this be fixed?
Check door seal, also if you remove top and put onto fill you can then see if the soap dispencer is leaking also pipe from soap dispencer to drum. Also it could be the pump leaking, this was common on some old machines.
Feb 12, 2010 | Washing Machines
Kenmore 665.16039403 leaks water when filling
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Sep 25, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Washing Machine
the main water valve that the fill hoses connect too in the back of the washer is probably bad.
Jul 25, 2008 | Indesit W 123 Front Load Washer
Drum filling with dirty water
hi as your machine got a non return valve on it to stop water from getting into your machine via waste pipe. worst case is call indesit as i am sure you now get 5 years parts g/tee as indesit is now part of hotpoint still cheaper than another machine hope this helps
Jul 11, 2008 | Indesit W 123 Front Load Washer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
280 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
