Ink cartrdige won't click into place - Office Equipment & Supplies
  • 295 Answers
Take out orange protective tab from cartridges and other plastic shields from kodak cartridge.use genuine kodak cartridge. ur issue will be resolved
Posted on Jul 27, 2009
Not printing red or pink
Hi patti,
Did you check the black ink cartrdige ???? To get red, their needs to be black ink involved which will darken the pink and give you red.
Also, make sure the nozzles are clean on the printer's print head. Take a Q-tip and alcohol and clean the printhead on the printer itself. Remove the cartrdige first. Clen the underside of the cartrdige as well.
Don't worry, alcohol won't harm the printheads because it dries instantly.
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us ForBrother Printer Support
Feb 17, 2014 | Brother MFC9320CW All-In-One Printer
My HP D1560 Deskjet Printer keeps blinking and computer says Cartridge Problems but I have refilled my ink cartridges like I have in the past---what do I do ? It won't let me print ? Ahhh Help
First of all understand what is cartridge the you can solve your problem your self in future if related same: The cartridge contains two parts 1. ink tank, 2. Pen(electronic nozzles controlled by mother board).. Ink tank contains ink & main source to pen to write,.. if ink is over you wont get any image.Ink is there but pen is not writing then no use..both conbination has work to gether to create image..As you said ink is there, but pen is not working due to ecetronic nozzles are faulty & this information with mother board, that's why its indicating that replace the cartrdige..And we can't repair it because of micro technology.
See fig: 1. Container, 2.Nozzles. 3. Electronic contacts to control nozzles..
Just replace the cartridge....
Feb 04, 2012 | HP D1560 Deskjet Printer InkJet
I have managed to instrall ink cartrdige 21 and 22 into Printer F2180, but where do I instrall the ink cartrdige no 58?
Do you have the right model # F2180 ?, I looked it up in HP & it list only 2 cartridges!!
Aug 26, 2011 | Computers & Internet
Cannon pixma ip3300 is not printing in black only color, (windows 7)
Does your blank ink cartrdige filled with ink?
Or before you print Click on the Properties button. Click the Color Tab\Print in Grayscale\Black ink only
Mar 18, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
I refilled my dell ink cartridges from Costco. Now my computer says "Low ink warning" How do I do a hard reset for the Dell 926 AIO Printer?
The ink is fine in the cartridge. The ink level indicator just thinks the cartrdige is still empty. You can ignore the message or turn it off all together. Just bring in your cartrdige for a refill when it shows signs of fading or streaking. Go to www.inkjet411.com for more help
Mar 10, 2010 | Dell 962 Photo All-In-One InkJet Printer
How do i re-fill my black ink cartridge
hp cartrdiges come with a coper circuit, refilling the cartrdiges might not work
Sep 26, 2009 | Office Equipment & Supplies
I want to use black ink in my cannon ip1800,is this possible?
of course it is possible for you to install black ink cartrdige to your printer. just contact your seller to get genuine black ink cartridge
Nov 11, 2008 | Cannon Office Equipment & Supplies
Ink cartridge leaked inside of my printer, how to best clean it & why would it?
It is very unlikely that the cartrdige actaully leaked*, more likely what you see is the service station area on the right side of most HP inkjet printers. It is normal for ink to be spit into this area to keep the nozzles healthy. If this is the case it is best to just leave it alone, the service station was designed to collect the ink. If there is a ***** of ink high enough that the top is scraped flat by the service station you could remove it carefully with a plastic spoon. To minimize ink in the service station follow a few guidelines: 1. Do not use an external power strip to turn off the power to teh printer. The printer should always be plugged into a live outlet. Using an external switch will result in the pritner losing track of the time since the last print job, with the result it will use more ink in servicing. 2. Do not run unnecessary cleaning cycles from the maintenance panel. A typical cartrdige would need one or less user initiated cleaning cycles during its life. Users that do a cleaning every day or even once a week expend ink unnecessarily in the service area.
If you have an older Deskjet 800 or 1000 series printer the following may apply.
For more details applicable to your situation please indicate which printer model you have, whether your cartridges are original or refill/reman and also wa tte nature of the leak is.
* If you are using OEM cartrdiges. If you are refilling it is possible to overfill or otherwise cause the cartrdiges to leak.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 01, 2008 | HP Office Equipment & Supplies
Photo ink cartridge
remove the black ink cartridge and insert the PHOTO cartrdige to the black ink slot and im pretty sure that it will perfectly work...
Aug 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer Toolbox Not Recognizing New Black Ink
The Deskjet 6940 will only show ink level for original HP cartrdgies. Refilled or reman cartridges will show as empty or unknown in the toolbox. This is not an issue with the driver, the cartrdige itself has information that it has been previously used and this is not resettable. You can continue to print with a cartrdige that has unknown ink levels, you will just not get low ink warnings.
Regards,
Bob Headrick, Micosoft MVP Printing/Imaging
Apr 24, 2008 | HP Deskjet 6940 InkJet Printer
k24674
