Question about Coffee Makers & Espresso Machines
My B150 dribbles out water when you try and brew a cup of coffee. if no pod is in the unit water flows fine.
3 Suggested Answers
NiftyInsight
  • 15 Answers
SOURCE: unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
Posted on Feb 21, 2010
mc1bean
  • 3053 Answers
SOURCE: using the k-cup..does not brew the water splashes everywhere
That is because most likely the part that punctures the k cup is most likely clogged, try using Like a paper clip and cleaning out the small hole and should flow. Mike
Posted on Oct 30, 2011
Just descaled my 2 year old SENSEO machine. Everything working well EXCEPT only coloured water comes out into the cup. tried with several different pods.
Hello, Chris -
The problem may lie with the small tube which pokes a hole in the coffee pod. The tube may be blocked by bits of coffee grounds or loosened scale.
You will need to remove the holder into which a pod is to be inserted.
You then should be able to snap the holder apart.
Then, you should find the small tube which pokes a hole in the pod for brewing.
Use an unbent paper clip to try to gently dislodge anything that may be blocking the tube. Do this over the kitchen sink while water runs over the tube.
There are also tubes which inject water into the pod. Find them and use the paper clip to dislodge any clogs.
Reassemble the coffee maker.
Without inserting a pod, run water through the machine in the brewing cycle - 3 separate times. Place a glass or metal measuring cup to collect the water. Notice if any debris comes out with the "brewed" water.
Then, insert a pod into the machine and run the brew cycle to determine if the coffee is properly brewed.
If the coffee still isn't brewed properly, I suggest you contact Senseo (owned by Philips) Customer Service by telephone. I have no idea where you live, so I cannot provide you with the correct telephone number to call.
I am answering from the USA.
Best wishes.
Apr 19, 2018 | Coffee Makers & Espresso Machines
My Senseo Coffee Machine works fine on the one coffee duck. But, when I use the 2 cups duck, nothing - just a few dribbles. Then I can't open the top either - it appears to be suctioned closed.
The 2 pod strainer it clogged. If you hold it up to the light you should be able to see light coming through the other side. Try soaking it in hot water for a half hour and than blow it out the center of the pod strainer with one of the compressed air/ gas duster cans. If this doesnt work than try a needle.
Mar 02, 2015 | Fire Sense Pool & Spa
Keurig B150 - My brewer was not brewing a full cup so I descaled it. Now it starts pouring out water before it is supposed to, i.e. water flow starts while it is "preparing" to brew, then it actually...
half and half water and vinegar clean it out free bruise try again if it still having a problem you may have something stuck in the brewer might have to see if you got a warranty if not sorry
Dec 31, 2014 | Keurig Coffee Makers & Espresso Machines
Using the k-cup..does not brew the water splashes everywhere
Oct 29, 2011 | Breville BKC700XL Stainless Steel
Fault F 17 appears when in use. Starts grinding the beans but no coffee in the cup yet. What does F17 mean?
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Jan 26, 2011 | Miele CVA4070 Coffee Maker
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
I have a Jura S9A that is about 2 years old, brewed about 1600 cups. Regular filter changes/cleanings. When I brew a coffee, it dribbles out, but makes a full cup of coffee. It also has trouble getting a...
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
Oct 10, 2009 | Jura Capresso Impressa S9 Coffee...
Unit will not brew when pod is inserted; works w/o pod however.
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
