Question about Kitchen Appliances - Others
Error code E4 keeps popping up on logik 6 liter pressure Cooker not sure how to clear this code to get it working again
Logik 6 liter pressure cooker not working Error code E.4
5 Suggested Answers
  • 7 Answers
SOURCE: E4 Code
The E4 Code, in my experience, occurs because the element is overheating.
What I found fixes this problem is a good cleaning of the bottom of the insert and a further thorough cleaning of the Heating Plate inside the the cooker itself that he insert rests on.
Hope this is of help to someone who has the recurring "E4" code with the Barvetti Pressure Cooker
Posted on May 11, 2009
SOURCE: e4 code on model epc460 pressure cooker
I have a programmable pressure cooker with no instruction manual. The model number is EPC460. It was made in China and just says Perfect Programmable Pressure Cooker. Can you help me find a user manual for this. I can't find anything online or by googling it.
Thank you
Posted on Oct 27, 2010
tunde007
  • 2382 Answers
SOURCE: E4 error on pressure cooker,
Hi, the problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. You will probably have to change the switch.
Another way to get rid of the code temporarily is to open the machine. Let it cool off by washing the lid and pulling the pan inster out of the base and let that cool as well. Then unplug the machine and basically start all over. The error will go away after some time.
Posted on Jan 04, 2011
emissionwiz
  • 75066 Answers
SOURCE: i have a logik lin64tcn
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Posted on Aug 30, 2012
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Error code e4
You can visit site: click here. to download or visit site How to use Elite pressure cooker Recipes for your Secura -Elite pressure cooker to see more free recipes and other manual pressure cooker.
Regard
Aug 23, 2013 | Secura 6-in-1 Electric Pressure Cooker...
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
Jan 13, 2012 | Washing Machines
When I try to set the time on my electric wolfgang puck pressure cooker, I get an "E4" and a beep. What is the problem?
I actually have one I use all the time at home. We LOVE it but this seems to a common issue.
the problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time.
I have come across this error when I am cooking rice and then trying to pressure cook something else immediately after. I have found that If I release the pressure valve and manually let the steam release, then my chances of getting the getting the E4 errror are less, but it recommends not to do that. :( Another way I have gotten rid of the code was to open the machine. Let it cool off by washing the lid and pulling the pan inster out of the base and let that cool as well. Then I will unplug the machine and basically start all over. The error will go away after some time either way, it's just unfortunate that it can't go from meal to meal when you have several different dishes you need to make. Don't THROW away your machine with an E4 error, just give it time to reset
Apr 07, 2011 | Vacuums
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 code
before using the pressure cooker make sure the bottom of the container is dry.. I got this error then i just wiped of the bottom of the inner container.. turned off the pressure cooker then turned it on again.. it worked fine after that.. no more error
Jan 24, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
E4 error....What is this?
before using the pressure cooker make sure the bottom of the container is dry.. I got this error then i just wiped of the bottom of the inner container.. turned off the pressure cooker then turned it on again.. it worked fine after that.. no more error.
you also want to make sure, when you use the cooker you have at least 1 cup of liquid in the cooker .. the measure cup that comes with cooker
Oct 25, 2008 | Wolfgang Puck 5-Quart Electronic Pressure...
Kitchen Appliances - Others Logo
29 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
