Question about Kitchen Ranges
Circuit diagram for wiring logik stove lfs-400a
  • 711 Answers
Check out this link. https://www.google.com/url?sa=t&source=web&rct=j&url=https://applianceassistant.com/ServiceManuals/f90553_viking_free_standing_gas_range.pdf&ved=0ahUKEwjDpJW_4rDTAhUh4oMKHbYNCzIQFgggMAI&usg=AFQjCNHp7KAp6xPQktBj1Q0HWbDyq3DP1w
Posted on Apr 19, 2017
I need a wiring diagram for connection of a 3-wire plug to my home panel - Square D, 240V, 200amp service panel.
We need to know what you are connecting. IF you are putting in a 220 outlet for stove, dryer etc. Are you in a mobile home?
Feb 20, 2016 | Square Electrical Supplies
Oven stopped working
If you are saying that the breaker in the breaker box has been tripped, then there is a problem with the circuit or in the stove. The circuit may be checked with a volt meter. If the problem is in the wiring circuit, the breaker will trip with the stove unplugged. The problem is most likely in the stove, and the stove's wiring needs to checked. If you are unfamiliar with 230V wiring and how to safely test the wiring, have an appliance technician service the stove.
Apr 15, 2014 | Ovens
I WORKING ON LOGIK TV LK74PF LOPT WAS FAULTY NOW IT HAS AND EAST WEST FAULT.THE EAST WEST TRANSISTOR 2SC5248 IS SHORT CIRCUIT.REPLACED IT BUT IT BLEW AGAIN.THE TRANSISTORS THAT DRIVE IT 2SC1815 AND...
Hi, The Logik lk74pf flyback that you replaced. What did you replaced it with. I also have the same tv with the same problem. Also found a 1k resistor blown in the supply line from the flyback to the vertical deflection circuit.
Sep 12, 2013 | Cameras
Need a wiring diagram for a rse37bal3
Your Frigidaire motorcycle has an electric stove?
Most stoves I have worked with in the past have had the wiring diagram glued either to the back or under the top. I have never seen one installed on a motorcycle, however.
Feb 16, 2013 | Motorcycles
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
MP4 Player, Model no: Jxd661+
on my jxd mp4 & mp3 player THERE IS WHITE SCREEN
Nov 26, 2009 | NRS Siemens Ite 400a 600v Circuit Breaker...
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
