Question about Answers Computers & Internet
I need answers to level h DD.1 - Answers Computers & Internet
Why is my vintage boss dd-3 very quiet on the repeats even when level is turned up full?
Assuming you have the feedback level turned up....can you hear any difference at all when adjusting the feedback?
Aug 17, 2012 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
F1 bottom drawer locked
F1 means the flood switch has been activated. here is a trouble shooting flow chart.
1. did a flood occure? yes. q-2 or no q-12
2. is the lid sealing on the tub correctly? yes Q-3 no=Answer
3. Is there a high water level in the tub. Yes-q4 no q-6
4. is the water valve leaking? yes=Answer no-Q 5
5. Is the dish drawer priming correctly? yes q-11 no q-6
6. Is the spray arm split. yes=answer, no q-7
7. is the spray arm running freely. yes q-8 no q=answer
8. is the water leaking from a split inlet or drain hose? yes = answer, no q9
9. is the water leaking around the heater plate or o rings. yes=answer, no q10
10. carroy out more testing to locate the source of the leak.
11. drain hose may have been blocked or partially blocked.
12. is there water or condensation around the chassis flood switch pcb.
13. if power fails to the bottom tub, it will cause the top tub to f1
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
DISHDRAWER IS SSHOWING FAULT CODE F1. WHAT ARE THE
Jan 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I hook up a G wireless router to my h/p computer
The usual setup is to connect your internet cable or dsl model to the WAN port on your wireless router. any devices that were formerly connected to your cable/dsl modem then get connected to the LAN ports on your router. You will need to connect to the wireless router via etehrnet cable the first time in order to setup your wireless connection, it's usually a simple setup following the prompts.
Sep 29, 2009 | Belkin (F5D8231-4) Wireless Router...
Vixen Telescope DD-1 Dual Motor Controller for RA and Declination
Vixen can repair your telescope-- and or the controller--
Contact OPT at this web site -- they are a Vixen dealer and can advise you about what to do--
http://www.optcorp.com/
Apr 10, 2009 | Vixen U.S.A. Great Polaris Telescope Mount...
Repeater router responds with 'Address not found...'
You need to start from scratch.
Whenever you need answers they can be found here -
http://www.dd-wrt.com/phpBB2/viewforum.php?f=1&sid=785382853553ee7844cfab78da0607db
But best to start with the Wili - http://www.dd-wrt.com/wiki/index.php/Installation
And here is your get out of jail card -
http://www.dd-wrt.com/wiki/index.php?title=Recover_from_a_Bad_Flash
If you have to resort to the hard method of recovery, be careful.
I have only ever permanently killed one router - doing this - http://voidmain.is-a-geek.net/redhat/wrt54g_revival.html
You will first need to establish which model router you have. Then you will (assuming you want to use DD-WRT firmware) need to flash a micro or mini firmware. Then you flash again, using the standard.
There are many users worldwide using your WRT54G and GL routers with other than standard firmware, me included. I manage a network of 9 routers running DD-WRT V23SP2 standard.
Don't give up, and when it says to leave it 30 seconds (or 2 minutes) DO! Be patient...
Apr 06, 2009 | Linksys Wireless-G WRT54G Router
Beeping and red light stating U3
Hi and welcome.
You posted your question in the DD/DS603 series section, but code U3 is usually seen on a DD/DS601 or DD602 series. When this code appears, most comon cause is that the machine is set in LP or LOW PRESSURE mode and needs to be set to HP or HIGH PRESSURE.
The fault is sensing water level too high in the drawer, which can also be caused by a blocked drain or inoperative pump. I can tell you exactly how to tell if the machine in in the wrong mode if you can tell us the correct model number. The machine's pump/drain system can easily be checked by putting the machine in diagnostic mode and running the drain pump.
Feb 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
May 05, 2008 | Ye Data YD-702D (850416000107) Internal...
How do I change the time?
The Macrotel Excel, Macrotel MT-16 and the Prostar 816 are all very similar in programming. The following information should work on all 3 KSU's of any revision or software level.
To Enter programming: Must be done before any programming
Depress # (Programming)
Dial 20 (MMC Disabled)
Enter Password [Default is 1234] {or it may be 4321}
Dial 1 to enter programming mode. Programming mode will turn off automatically after a few minutes of non-use.
Dial # again
Then
To change Time and Date:
Depress
# (Programming)
Dial 55 (YY MM DD W HH MM)
Input new data:
YY= year
MM= month
DD= day
W= weekday [0=Sun 1=Mon 2=Tue 3=Wed 4=Thu 5=Fri 6=Sat]
HH= hour (24 hour mode)
MM= minute
All data must be entered each time or changes will not be saved.
Dec 04, 2007 | Samsung Prostar 824 Keyset Telephone
Computers & Internet Logo
Top Answers Computers & Internet Experts
Vernon Taylor
Are you an Answers Computer and Internet Expert? Answer questions, earn points and help others
