Question about Ovens
Need wireing diagram single phase for blodett mark 5
    Sniper:
  • 71 Answers
Hi
I found a service contact where they can provide you with a diagram
MIDDLEBY UK LTD
4 Cranford Court
Hardwick Grange, Woolston
Warrington WA1 4RX
England
Tel: 44-1925-821280
Tel:
FAX: 44-1925-815653
there is a website also with service and literature available to dowwnload
http://www.blodgett.com/
Hope that helps
Posted on Jul 25, 2009
    Scholar:
  • 81 Answers
I'll need the volts (120/208/240) single or three phase, model # & serial # plus your e-mail so I can send you the scan.
Rick
capt_rick1912@yahoo.com
If I have a double 30 amp breaker can I plug in a cooker that needs 208 volts single phase, the plug and wall receptacle match
no
the house wiring for single phase outlets is rated to 10 amps and what you intend to do will burn the wiring
you will have to install a dedicated circuit that is capable of carrying the full 30 0 amps
contact an accredited electrician for correct advice and how to do it
Oct 17, 2015 | Ovens
Proper Gaggenau EB294 Oven Terminal Block to Cable Harness wiring
If its brand new, most possibly the electrician did not bridge the mains connection.
It sounds like an installation fault.
There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection.
Oshie
Apr 09, 2008 | Gaggenau EB294/295 Electric Double Oven
It is wired for 3 phase can it be wired single phase
3-phase is a way to supply more power on similar wires. If your oven is designed to be run off 3-phase, then it will need that. I've not seen any residential ovens wired that way, though. What makes you think it's wired 3-phase? If you are in the US, it's likely wired for 230v, which is 3 wires, but not 3-phase.
Jun 02, 2015 | Ovens
How do i connect this single phase
three wire, or four wire? are you talking about connecting pigtail to oven? more info, or a photo
Apr 17, 2015 | Ovens
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
I take it the wiring harness in front of me is 3 Phase. I have a Green wire, Red, Black and White. The wiring diagram on the back is marked L1, L2, N, E. Just need to know which wire goes where thanks.
It is not 3 phase...just single phase 240V....L1 goes to the one hot side of the 240 v, l2 goes to the other hot side of the 240V, N goes to neutral, and green goes to earth ground (metal box)
so....L1=Black L2=Red N=White E=Green
Jan 22, 2011 | Ovens
Need to change oven from 440 3 phase to 220 single phase hobart cn90 oven
It can be done with a transformer, 480/ 240 single phase transformer to get the lower voltage. Then the oven will require some wiring changes to get all the elements and controls connected to two hot wires instead of three. The transformed will be sized to the wattage rating of the oven. This is a only basic description of what needs to take place.
Sep 05, 2009 | Hobart Ovens
Lincoln Conveyor Oven - 1132
Switching phase on products are usually up to UL. You need a good tech and it can be done. If it is marked 3 phase and you make a single, the responsibility falls on the person that did the conversion. Components should be similar from 3 phase to single, just use OEM parts!
Sep 04, 2008 | Lincoln Conveyor Oven - 1132-080-A
Blodgett Mark V, Sinking Cakes
They can help you here. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Dec 22, 2006 | Blodgett Model Mark V Single Electric Oven
Ovens Logo
140 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
