Question about Cell Phones
Tried to logon last night after I registered and it will not accept my phone
DVR 16 CH night owl. How can I reset the password?
As a security precaution, maker only allow password resets via our theirTech Support staff. Please register your product and contact technical support by phone. link below has info.
PRESS THE HELPFUL BUTTON AND FOLLOW ME ON FIXYA FOR MORE INFO
Night Owl Security Products
night owl dvr telnet default logon password CCTV Forum
http://www.pcrichard.com/images/manuals/P-45-4624N-manual.pdf
http://static.highspeedbackbone.net/pdf/Night%20Owl%2016-CH%20500GB%208-Camera%20Security%20Kit%20Manual.pdf
Feb 05, 2016 | Home Security
My Straight Talk Huawei says it has no service but was working last night and now just wont send messages what is going on
1. Did you pay the bill? Check with them, maybe your service got cut off.
2. If it isn't #1, Take the SIM card out and put it back again, maybe the SIM card is faulty.
3. If possible, go to settings, mobile network, and choose to search for your wireless carrier, once it pop up, tap it to register.
4. You also must make sure your APN is in order. And have the correct APN check for Straight Talk.
Oct 10, 2014 | Straight Talk Huawei Ascend Y Cell Phone
Phone won't register paid air time
Contact Tracfone for assistance.
Mark
Motorola Support
Aug 11, 2014 | Motorola Mobility TracFone C139-4 Cellular...
How do we get the phone to work, we are registered and received confirmation that our current phone number could be transferred, but should we call our current carrier.
I had a similar issue when changing suppliers in the UK. I had to get a PAC code from my old supplier to give to my new one so they could transfer my number over to them. I then discovered that my phone had been locked to my old supplier (the manufacturers auto lock some phones to the first network you use on the handset). Check your phone for a "network locked" message. I used an online unlock site which cost £7.90 and my phone was unlocked within 30mins. The old supplier took 9 days to send me an unlock code. I hope this helps.
Jan 02, 2018 | magicJack pc to phone, free local & long...
User profile service failed the logon, user profile cannot be loaded
try F8 when you restarting computer, and choose last knowing good configuration
Dec 17, 2013 | Microsoft Windows XP Home Edition
HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
I have a Blackberry 8330 that was received from the store last night...about 15 hours ago. This phone was a replacement for a lemon that was received and now this phone has no browser...how do I get the...
You may have to call your cellphone provider to get the service pushed; however, try this before you do:
Goto Options
then Advanced Options
then Host Routing Table
There should be several entries from your service provider, roll over the hight lighted entry (should be one) and press the menu key.  Select Register Now.
You should get a message stating that you have register successfully.
Your browser service book was lost during the phone replacement and usually all your services are restore when registering.
Hope this helps,
Bill
Oct 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Logon problem with Compaq notebook!
You're welcome, you can rate this now. Good Luck.
Oct 31, 2008 | Compaq Presario Notebook
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
