Question about Garmin nuvi 250 GPS Receiver
Can not turn on! my garmin nuvi 200w I think it is locked,
I tried to connect to computer thru USB, screen is black.
Tried to reset, pushed on buttery button - nothing!
    Brigadier General:
  • 4,090 Answers
If ther battery went totally flat place it on charge for an hour or so to revive it. Max battery life in storage is 4 days with a good battery.
Charging it even tho the charge light may not show should build up enough charge to eventually show the light and allow you to turn it on. It should remain on charge for 5hrs.
Other possibility is a collapsed cell in battery, replace the battery
Posted on Jul 26, 2009
My garmin nuvi 2595 lmt will not turn on, recharge, nothing but a black screen. I pressed what i think was the reset button several times but nothing. Once I heard a sound as if it was going to turn on...
Take a look at rear USB port. Insert the plug. Gently wiggle the plug. Does the USB port appear loose? A common problem with this model is that there is little mechanical support for the USB connector. If it breaks off of the printed circuit board, there battery will nit be able to be charged and the unit will appear dead. Have you tried holding down the power switch for at least 10 seconds?
Aug 14, 2013 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 200w keeps going into mass storage mode when plugged in to charge.as soon as it is plugged in to charge the screen appears that shows the garmin plugged in the computer. and the map...
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
Aug 06, 2011 | Garmin nuvi 200W GPS
I have a Garmin 200 GPS and it will only turn on for a few seconds before going to a black screen. Ive tried to use a webupdater and it would not recognize the device. It will come on if I plug it into a...
Look near the serial number there should be a reset button there. Also make sure when you connecting your Garmin to the computer do not use a USB hub connect it directly to a USB port on the pc. I have attached a link to the manual for your unit. Thanks for using FixYa
http://g.factoryoutletstore.com/pdf/garmin/010-00621-18.pdf
May 17, 2011 | Garmin nuvi 200W GPS Receiver
I have a garmin nuvi 200. I'm having problems trying to charge the device. I have tried charging it in my car as well as the computer. Once I try charging it a black screen appears that says garmin as...
This is meant to happen when it's connected to your computer but not to your car charger. Sometimes it happens, when connected to a car charger, because the mini USB plug on the charger lead doesn't go in far enough into the satnav. It feels like it's fully in but it's not. If you push it in further it should solve the problem.
It takes 8 hours approx to charge a satnav connected to your computer but only 4 hours approx with the car charger or mains charger.
Apr 22, 2011 | Garmin nuvi 200W GPS Receiver
My Nuvi 200 screen went black. I've tried turning
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
Unit Cuts Off
Sent unit back to Garmin.
Apr 02, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 250 GPS Receiver Logo
542 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
