Question about Refrigerators
Cannot remove plastic film from freezer portion of fridge. Almost like it is melted on. Any suggestions?
  • 1462 Answers
SOURCE: fridge not working
almost certainly a compressor fault. not worth repair
Posted on Sep 02, 2008
SOURCE: samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: all of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Posted on Apr 18, 2009
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
SOURCE: Remove Faceplate on fridge
I am have the very same problem. I removed the dish beneath the water/ice dispenser, and located two small screws. These two screws appear to hold the bottom of the face plate to the door. I removed them. However, the faceplate still did not come loose. I suspect there are more screws or clips toward the top.
Posted on Dec 12, 2009
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Freezer compressor is short cycling
Sep 06, 2013 | Electrolux Refrigerators
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
Samsung fridge freezer RL38SCSW fridge isn't cooling freezer is fine please help
Hi Hannipan,
I know this is a bit late but it should help for others. We had the same problem with our RL38SCSW (caused by the freezer door being left ajar for the day) the problem is caused by the freezer trying to cool down the unit and goes into overdrive by freezing all the cooling coils in the back. The air can't circulate (via the use of the fan) and so the freezer stays cold but no cold air travels up to the fridge.
Take out all of the freezer trays and behind there is a plastic cover held in by one screw, remove this and carefully remove the cover (the top part needs to be pressed downwards to release) under there is a grey plastic cover this will most likely be frozen to the back so don't pull it. Use a hair dryer and try to melt the ice. Remove two more screws which hold it in place and eventually it should come out easily. Now you can see the coils behind are frozen up, leave them to defrost (don't chip at them! or alternatively use a hairdryer to help melt the ice) Once it's de-iced put it back together and you'll be good to go again.
(Make sure you don't keep the hairdryer and one area of the fridge you'll melt the plastic and also make sure you turn off the freezer at the plug before working on it)
Jan 28, 2013 | Samsung RL38SCSW (113 cu ft
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Found water on floor and found that freezer is no longer freezing.
Hi
The problem could be a bad defrost timer, could be low on Freon. Pull the back of the freezer out, you'll have to remove all the food (yep, from the inside). This will expose your condenser coils. If it’s one big block of ice, then your defrost timer is bad. If the condensers are only lightly frosted on a portion of them and nothing on the rest of them, then your unit is low on Freon.
OR
You've got an iced up evaporator. If you look in the lower section of the freezer on the back wall, is the wall frosty or icy looking? The only way to defrost this is by taking the back wall out of the freezer and using a hair dryer on it (being careful not to melt the plastic liner) or to just empty the whole thing and let it sit with the doors open for a few days. Be prepared for water to leak out from under it however as the ice melts and overflows the drain tray in the bottom of the fridge.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jun 30, 2010 | Kenmore 57029 Side by Side Refrigerator
My Maytag wide by side is leaking water from the
Yes. Your defrost drain hole in the lower rear of the freezer is frozen over with ice. Turn off the fridge. Remove the shelves and bins from the freezer side. Break up any ice on the floor of the freezer and dispose of it. Use a hair dryer to melt the ice over the drain hole in the rear portion of the freezer. Once it is clear pour a 1/4 cup of bleach into the drain hole.
Dec 20, 2009 | Refrigerators
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
