Question about Rockford Fosgate Car Audio & Video
What would cause 1 channel of a Rockford Fosgate T800.4ad 4 channel Amp to fry speakers while there are no such problems with the other 3 channels?
Fosgate T800.4ad 4 ch amp right front channel fries every speaker I connect to it while there are no such problems with the other 3 channels. What could be the cause of this problem. I connect speaker to that channel and it puffs up and begins to smoke. Help! Thanks in advance
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Question: what starts to smoke, the speaker or the amp? I'm assuming it's the amp. It cant be a fuse because that's what fuses are for to cut the power on an overload or surge. I would have a look at you circuit board for the amp My guess is what you;ll find is a burnt spot on the board and that will tell you what component is bad and needs replacing. Good Luck
Posted on Apr 19, 2017
Testimonial: "It's the Speaker that starts to smoke. The amp doesn't Smoke and that channel gives off powerand plays music through the speaker, but for some reason it burns every speaker I hook up to it. The speaker will puff up and stay puffed until it burns out."
  • BigAce
    BigAce Apr 19, 2017
  • Scott Gardiner
    Scott Gardiner May 06, 2017
    Mine does the same thing no burnt spots or components plays music but burns up every speaker that's hooked up to it any real advice would be appreciated thanks
How do I hook up my inside speakers and sub's to
if setup 4 channel amp with low pass filter for the sub channel and other 2 channels for speakers with no filter, some amp you can use amp as 3 way if one or two subs, bridging output will give you more power for the sub. be aware that bridging 2x4ohm subs will give you 2 ohms and potentially damage the amp.
Oct 21, 2014 | Car Audio & Video
How many peak watts is a rockford fosgate p500/2 amp...i belive it is the last gen...the one with the silver cover plates...thank u
Rockford Fosgate P500-2 is capable of delivering 125Watts to 2 channels @ of 4 Ohms speakers, and 250Watts to 2 channels @ of 2 Ohms speakers.
Dec 29, 2011 | Rockford Fosgate Car Audio & Video
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
1 channel is out in my Rockford Fosgate P6002. One day everything is working and 2 weeks later the one channel went out. I have the amp hooked up with 2 12'' DVC T2 or T4 Eclipse Subwoofers, sorry not...
Hello jason_dil,
Having 1 channel go out is a common problem with audio systems. Unfortunately, since it can be caused by faults in the wiring, head unit, amp, or the speakers themselves, it is tedious to troubleshoot. Being tedious doesn't mean that it is difficult. You can do it with a little planning and organization.
Here's a link to which has pages and pages of step-by-step troubleshooting. I recommend that you read up just a little and print out any of the guides you need.
What you want to do is eliminate what ISN'T causing the problem and isolate what is.
1) First, do a physical check of all the wiring. Make sure all connections are secure and tight and that there are no obvious cuts, tears, or breaks in the insulation. Check all fuses. Either replace them with known good fuses or remove and check with a meter. Check RCA's plugs on both ends. Remove and reseat each plug. Make sure the pin is not broken off inside.
2) Move on to the defective sub and it's wiring: See if it works on the other channel.
3) Check the head unit output: Reverse the channels of the RCA's and see if the problem switches to the other sub.
4) If everything checks out in 1-3 above, you've isolated the problem to the amp itself. It probably has a faulty component and will need to be repaired or replaced.
Hope this helps. If it does, please rate as "FixYa". Thanks!
Apr 20, 2009 | Rockford Fosgate Car Audio & Video
Sony xplod 500w 4/3 channel
If the speaker is a 4 ohm DVC (two 4 ohm coils), you can't wire it to get a single 4 ohm load. Try connecting one coil to each of the two rear channels. It may not be as loud but the amp should operate without going into protection.
If the two 4 ohm coils are in parallel, the amp is driving a 2 ohm mono load. That's probably why it's shutting down.
Apr 25, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
P5002 rockford fosgate
If you hook up speaker and hear a pop you more then likely have 1 ch blown causing dc on output. You can use multimeter and measure voltage for both ch,s between positive and negative terminals..One channel will more then likely measure 0v and the other one which is defective wll measure a dc voltage. These amps have what are called mehsa bars which output transistors are mounted to. Need to contact Rockford fosgate 800-669-9899 to arrange for flat rate repair.
Jan 16, 2008 | Car Audio & Video
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
Rockford Fosgate P4002
Yes they are ! And that means the DC is on the speaker and will for sure damage the speaker if it already hasent
Jun 15, 2007 | Rockford Fosgate Punch P4002 Car Audio...
Car Audio & Video Logo
125 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
