Question about Miele Refrigerators
Can I replace the thermostat on Miele fridgeK8452S?
Miele technician said the thermostat was located in more then one place and not replaceable. he said I need a new fridge as thermostat was broken. Is he telling me the truth?
SOURCE: How to install Amana part number 12001937 Thermostat kit
I have a Sears Maytag with a cooling problem. Meat is frozen but bread is soft. I am told it is a Amana. It is a bottom freezer. Did this part fix your problem. Let me know, I am going to rip mine down in the am. Bandit98
Posted on Jan 26, 2008
SOURCE: Candy CPCA270FFK Thermostat replacement
if your refrigerator is in warranty than contact your service authority......or if you had purchased it by your own than ...... my friend! the thermostart does'nt have any warranty
Posted on May 14, 2009
  • 286 Answers
SOURCE: wine fridge thermostat
No pictures, the new one goes in the same as the old one comes out. You have 2 screws on the bottom of the evaporator that holds the sensor in place. Then the sensor runs thru the bottom toward the back.As you remove the old one jus put the new one in the same way.
Posted on Oct 08, 2009
  • 70 Answers
SOURCE: Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Posted on Mar 29, 2010
SOURCE: 2002 Honda Odyssey thermostat replacement
I have the same problem, anybody out there have a solution?
Posted on Dec 20, 2010
Miele tumble dryer
Maybe time to replace it. How can it be too much detergent? That would have the effect of lubricating the seals!
Mar 04, 2014 | Dryers
Miele t4262c not heating up
The thermostat is jammed-located behind the rear central panel,
Remove the 4 screws and prise of panel to reveal the thermostatic switch which is held in by one screw and the heat element that is held in by metal tabs. Both these items have 2 wires attached. Unscrew thermostat and chuck it on the floor a few times to juggle and reset. Really. Replace and enjoy the heat back !
Sep 12, 2012 | Miele Dryers
I would like to know location of reset button on hot water heater
If you have tank-type electric water heater, ECO reset is located on upper thermostat which is behind panel on side of water heater.
Be sure to put insulation back in place when finished so thermostat not exposed to cool air that will cause temperature misread.
If you have gas water heater, call service technician, and/or read manual.
ECO reset requires gas control valve replacement in many cases.
FV lockout requires replacement parts.
Some tanks have resettable thermal switch located behind gas door panel.
If you have tankless, call service technician, and/or read manual.
Apr 21, 2011 | Water Heaters
Can't seem to get heat My Miele dryer is 3 years old
if your condenser is blocked the airflow is restricted and can cause the thermostat at the rear of the unit behind the cover to create an open circuit. you would need to remove the rear cover and check with an electrical meter to see if the thermostat has resistance. it looks like a small round disc with a wire going to each side of it. you can order a replacement thermostat from Miele but remember to also clen your condenser before running it again.
Hope this helps.
May 30, 2010 | Miele T9800 Electric Dryer
Miele pyrolytic oven: error 90
F90 is a faulty oxygen sensor. This fault clears after resetting your circuit breaker for 24hrs only. you will not be able to use any automatic programmes as the oxygen sensor measures the moisture in the air and then decides how long to cook for. You will need a Miele service technician or a registered service agent to replace the oxygen sensor. This should be covered under warranty but check with your local Miele dealer first.
Mar 14, 2010 | Miele DG 4080 Stainless Steel Electric...
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Jun 14, 2009 | Miele DG 4080 Stainless Steel Electric...
go to and look in the compounts list for that year car and it will tell you excatly wher it is located.
Feb 19, 2009 | 1992 Toyota Celica
Miele no heat
The last I checked, the G660 will not work for the G665. If you look under Applicances in your phone book, you will see several appliance repair places. Most of them can get you universal kits to replace this. I however caution however that you should really let a tech look at your dishwasher. Something tells me that boards got shorted out by mistake without realizing it.
Mar 10, 2008 | Miele 24 in. G665 Built-in Dishwasher
Refrigerators Logo
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
