Question about Samsung Refrigerators
I have a Samsung 2 door fridge/freezer. The ice maker seems to be making a strange noise, sort of like a whoooo sound. Everything is working well. Any suggestions?????
HVACRH20
  • 237 Answers
SOURCE: Ice Maker Making Noise
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Posted on Nov 10, 2006
Pyrhyc
  • 2028 Answers
SOURCE: Amana French Door Bottom Freezer Refrigerator making noise but not making ice
The noise you hear is the ice maker trying to make ice without a water supply. Check the line to make sure you didn't knock anything loose or kink it when changing the filter, and check for a plugged line. It could be that there is ice build up in the line, a defrost will cure that.
Posted on Jul 08, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 409 Answers
SOURCE: Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Posted on Oct 03, 2008
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
Why is the freezer not freezing and why is the ice maker not pruducing any ice?
At -6, the freezer is freezing. If it's not producing ice, the ice maker may not be getting water. The water line could be kinked going to the refrigerator. The water filter, if it has one, could be clogged or installed backwards.
Jun 30, 2014 | Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
My Samsung RF265ABWP French door refrigerator has suddenly stopped making ice. I hear the old familiar noise it used to make just before I heard the ice drop in the bucket, only no ice drops. It sounds...
Is it getting water? If not, Most likely water valve is faulty and not letting water through, or feed tube through back freezer wall to ice maker is frozen which would be caused by dripping valve. It's either the valve or the ice maker not sending voltage to valve.
Nov 12, 2017 | Samsung RF265AA Bottom Freezer French Door...
Having problems with ice maker. Was slowing down it seemed in making ice... and now it does not seem to be making ice. I tried the fast freeze ... still no ice. Obviously must be a water problem... the...
I had the same problem and the Samsung customer service person told me to set freezer to -2 degrees, remove the ice bucket, press and hold test/reset button (look for arrow on top right of ice maker inside the fridge), replace the ice bucket and wait 24hrs.
Dec 02, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
Loud noise from the freezer side
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge Freezer issue
If it is a HMMMMM...CLICK sound it is the relays. (approx. every 30sec or so).... OR, condensor fan located next to the compressor.... Otherwise it is more than likely the fan(evap Fan)!
Goodluck,
Brian
Jul 07, 2008 | Samsung RS2630SH Side by Side Refrigerator
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Profile stainless Steel side by side
Can u pin down a little more like coming from freezer or back by compressior? Could be one of you fans.. one in freezer .. one by compressor in back
May 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
