Question about Samsung RS261MD 26 cu. ft. Side by Side Refrigerator with 4 Tempered Glass Spill Proof Shelves, Power Freeze/Cool Options, LED Lighting, Compact Icemaker, Door Alarm and External Ice/Water Dispenser
Ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix?
When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
2 Suggested Answers
goodwinpeg
  • 744 Answers
SOURCE: Samsung RF260BEAEBC ice maker stopped working for 2 weeks. It just started working again. Have no idea why. How do I diagnose the cause?
Hello James;
My name is peter. I am a retired field service refrigeration technician.
It is not uncommon, especially with the flex mold type ice makers to have a ice cub jam the operation. I have gone on many a service call to find this the problem. I suspect over a period of time the vibration of opening and closing the bottom freezer door may have jarred it loose. Your rocker arm may also have been stuck.
It is not common but possible that the ice maker water solenoid valve spool may have been stuck. I would check this by gently tapping on the solenoid valve with a tool. It may have freed itself once again over time through normal operation vibration.
Posted on Jan 09, 2015
Testimonial: "Peter...thanks for your answer. Ill give your suggestions a try."
Icemaker is not working properly. It will only make ice after the reset button is pushed.
If the ice room is not getting/staying cold enough, the unit will not harvest the ice and proceed through the cycle... First step in troubleshooting is to determine if the compartment the icemaker sits in is cold enough, if it is, then you have to test the ice room temp. sensor to see if it is not sending the correct temp signal to the main board. These icemakers are modular and pretty much have to be replaced completely if the temperatures and sensor check OK. Samsung Refrigerator Temperature Sensor DA32 10104N
Jun 21, 2016 | Samsung RF263BEAESR Stainless Steel 26 cu....
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
No water flowing to ice maker
to see if icemaker is still good pour a 1/2 cup of water into tray and wait for a day. make sure shutoff arm or switch is on or down (arm down) if it makes ice then the icemaker is ok. if it dont then hold up.
if it makes ice then either the water pressure is too low (or no water) or the water valve is bad. (to check water valve you need a volt meter).
ok back to hold up part... the icemaker actuallys controls the water valve so you can have no water but that doesnt mean the icemaker is bad. so here are the three possiblities to your problem:
ice maker
water vavle
not enough/no water
before you buy anything let me know and we can go over this again
hope this was helpful (or confusing sorry)
Apr 02, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Samsung RS261MD 26 cu. ft. Side by Side Refrigerator with 4 Tempered Glass Spill Proof Shelves, Power Freeze/Cool Options, LED Lighting, Compact Icemaker, Door Alarm and External Ice/Water Dispenser Logo
88 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
