Question about Irons
I have just descaled my steamelite iron, plugged it in and nothing is happening. It pumped as it should but the 3 lights on the right hand side are on.
3 Suggested Answers
SOURCE: Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Posted on Apr 08, 2009
SOURCE: nothing happens
Check the cord feed onthe part when it comes to the iron sometimes there got cable broken on the inside
Posted on Jun 03, 2010
Why has the steam function has just stopped working - power on but nothing happens
My wife has one of these irons and she loved it. Now it steams for a while, and a red light starts blinking and it stops steaming. It can be turned back on and works for a while, then the same thing happens. I read that it needed descaled, so I bought OUST descaler and ran it through the iron, but it did not solve the problem. Any one have a solution to this problem, I would like to hear from you.
Jul 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Iron is leakin onto clothing while ironing
Leaking irons happen more frequently when performing lower temperature ironing. Minimize the chances of this happening by doing the articles that require less heat with a dry iron. When you're ready to do the articles that require higher heat settings, add distilled water to the iron after allowing it to cool first (some folks suggest using rain water as it will lack the minerals contained in the soil - where water pumped from the ground picks them up).
Distilled water is recommended by manufacturers for irons. Use of regular tap water will cause mineral deposits to form inside the iron that can build up and even clog the openings on the bottom plate. These can contribute to stains on the material being ironed, too. If you are unable to obtain distilled water, you ought to descale the iron regularly to remove deposits that will form by heating water or allowing it to simply evaporate. Distilled water lacks the minerals to be deposited by either of these situations. If distilled water is used - there is no need to empty the iron before storing. Tap water - whether supplied by the locality or a well is loaded with minerals and may be treated with fluoride, chlorine, etc.
Descaling
an iron is pretty straight forward - no more difficult than descaling a coffee maker. Empty the iron of any water. Partially fill the iron with white vinegar and turn on to heat. Iron and old towel or rag to allow all the vinegar to pass through the steam openings.When empty, repeat once or twice - but with fresh distilled water to flush any remaining vinegar from the iron. When satisfied that the vinegar is out, store the iron. You can purchase products expressly made for descaling irons - just like you can for coffeemakers, but vinegar is a great low cost solution that works very well.
I hope this helps & good luck!
Oct 14, 2011 | Micro Pro 7599 Iron
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
When using the steam it spits out sediment on the clothes. I have tried cleaning by holding the steam button.
This happens due to limescale and / or build ups of mineral deposits such as iron in the water. You will need to use a kettle descaling solution or an iron descaling solution available from most supermarkets or home appliiance stores and clean out the debris in the iron. It happens to most if not all irons and cleaning on a regular basis is the only answer or use very expensive 'iron water'
Sep 28, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
HOW DO I DESCALE A STEAM GENERATOR IRON
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Dec 19, 2008 | Maytag MLI7500A Iron
Red light flashing
Feb 07, 2008 | Braun SI6225 Iron
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
