Coreldraw denied to open file
One of my favorite coreldraw files stopped to open, and it showed me: Error reading a bitmap in file 12Tomaf.cdr. No one of methods I knew didn't aid me, even search in google how to restore corel draw file.
    New Friend:
I suppose that there is a way to get .cdr file back. One of them is this application has free-to-try version - but its advantage in getting back to 5 .cdr files for free above its rivals.
Posted on Apr 20, 2017
Can someone help me whith Corel Draw file?
Your file may be corrupted or it could be your operating system.
You can use CorelDraw Fix Toolbox
Here the link:
It recovery corrupted .cdr files powered by the CorelDraw image editor.
Good luck,
Sep 01, 2016 | Corel Computers & Internet
How do I repair a corrupted CDR file?
try the following:
- rename the file to ".zip "
- open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
- try to repair the file
- then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
These steps work for me.
Or try use CorelDRAW Repair Kit. CorelDRAW file repair software for recovery of the contents of damaged CDR files. Program helps to repair corrupted Corel Draw project files.
Corel Draw repair file
Jul 18, 2015 | CorelDRAW Graphics Suite X4 for PC...
How do i fix CorelDraw?
Hi, these steps work for me.
1. rename the file to ".zip "
2. open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
3. try to repair the file
4. then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
Maybe that utility might be what you're looking for - CorelDraw Fix Toolbox
Or see more
Jan 23, 2015 | Computers & Internet
How to cdr repair corrupted image?
If you are using windows 7 or later, you can try opening the folder in windows explorer, right click on the CDR, go to properties and then the previous versions tab. It may have kept an older version.
I can't remember if XP also kept previous versions and it also depends on your configuration, so it is not definite that you will have them.
Another, small, possibility is to look in the same folder and see if you have a file which begins backup_of_... and your filename. But this keeps only one previous copy so if you have saved the file more than once since Wednesday your backup will be too new.
CDR Repair Kit. A must-have CorelDraw CDR repair tool for all categories of users seeking a reliable method of restoring their CorelDraw images after data corruption accidents of various types.
For more information:
And here:
Nov 06, 2014 | CorelDRAW Graphics Suite X4 for PC...
Error reading problem in x6 , i tried to open it in other computer as well but it shows the same problem for my .cdr file...
At problem opening in other computers evidently .cdr file is invalid. Make use of cdr repair article helps you to successfully open the file
Dec 25, 2012 | Computers & Internet
Error reading coreldraw x5 file
If you are reading off a CD/DVD make sure it is clean and there are not and spots or scratches. If you are reading from a file off a server then you could easily have a corrupted file. Check the file length and make sure it is not zero. Anyone else?
May 24, 2012 | CorelDRAWdent Suite X5
What is a M.cdr file and how can I burn it to dvd to watch on dvd player?and the same for a dmg file?
Detailed information for file extension CDR: File classification: Graphic Mime type: application/cdr, application/coreldraw, application/x-cdr, application/x-coreldraw, image/cdr, image/x-cdr, zz-application/zz-winassoc-cdr Identifying characters: Hex: 52494646, ASCII: RIFF
Program ID: CDraw4 , CorelDRAW.Graphic.8 , CorelDRAW.Graphic.9 , CorelDRAW.Graphic.10 , CorelDRAW.Graphic.11 Associated links: XnView Other applications associated with file type CDR:
  • Elite Plus Commander Saved GameThe Identifying characters used for this association are:Hex: 45 4C 49 54 45 20 43 6F 6D 6D 61 6E 64 65 72 20 46 69 6C 65 1A , ASCII: ELITE.Commander.File.
  • Final Cut Pro CD/DVD Image File by Apple Inc.Final Cut provides Mac users editing tools, sound design, real-time motion graphics and DVD authoring. CDR files are ISO images and, if moved to a PC, can be renamed and burned as ISO files. Associated links: Ken Stone's Final Cut Pro Website
  • GameJack Virtual CD or DVD Image by S.A.D. GmbH.Appears to be an older extension. GameJack seems to use .XMD now.
  • Raw Audio-CD Data
  • Sound File This association is classified as Audio. Associated links: Linux Player
The DMG file type is primarily associated with 'Macintosh OS X' by Apple Inc.. On the Macintosh, these files are treated like a real disk. They can be created with Disk Copy, burnt to CD or mounted as a normal volume. The DMG file also comes in different formats: HFS, HFS+, UFS, ProDOS, Linux, and Fat32 and so may also require special mounting software to account for the format. IsoBuster can interpret these files directly as can other programs such as UltraISO. The program TransMac, by Acute Systems, can both open and create DMG files on a PC.
Oct 22, 2009 | Apple iMac 24" Desktop
Can't open Coreldraw 12 file
convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
Feb 26, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Computers & Internet Logo
David Payne
David Payne
