Question about Black Office Equipment & Supplies
My ip4940 print black on paper but not on cd - Black Office Equipment & Supplies
Wh is my canon ip4940 saying there is no print head
take it back out again and clean the connection in the back where the circuit board is
Aug 14, 2014 | Canon IP4950 Pixma Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Pixma MP610 - fab machine - only problem is that the large of the black cartridges empties - never uses the smaller one (No 5) why? It refuses to print if the No 8 is empty. What do I need to do please?
The large of the black cartridge (5) is for ordinary paper in printing menu of computer. Selecting photo paper uses only the small black cartridge (8) and the color cartridges are used to make black even for gray black printing. Choosing ordinary paper, you can print in black 10 even 20 times with the large black cartridge (5) (by refilling and quoted as empty) . You simply need to press a long time the hold button, as explained in the manual on the printer CD, to continue to print with an empty cartridge. (at least in Europe)
The color cartridges are slightly used even when printing only in black and become empty, even if you never use the colors!
Jul 28, 2008 | Office Equipment & Supplies
Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
Black ink on glossy paper looks like leopard spots
printer need head cleaning , after cleaning check nozzle , if solid color appear w/out space on black color it means good and clean nozzle.
Dec 27, 2007 | Epson Stylus CX6600 All-In-One InkJet...
23 people viewed this question
Top Black Office Equipment & Supplies Experts
Walter Dominguez
Level 1 Expert
Lawrence Oravetz
Are you a Black Office Equipment and Supply Expert? Answer questions, earn points and help others
