Question about Home
Knives for my yhp 150 plainer - Home
How do I get rid of Yahoo from opening whenever I open Chrome when I have Google set as my default search engine?
open chrome go at setting
on startup - open specific pages add and remove yahoo from there .
then down at search
Set which search engine is used when searching from the omnibox.
add google
Oct 06, 2015 | Computers & Internet
Which knives do I need to have a full set of kitchen knives?
Actually it is much simple than it sounds, you will only need 4 types of knives to have a complete set of kitchen knives. You need a chef's knife a paring knife a filleting knife and a cleaver, that's about it. You can perform almost any cooking task there is in the kitchen with those 4 knives.
Jul 25, 2012 | Camping, Backpacking & Hiking
I have a table top plainer i need to gauge new
Yes, there is only one way to do this right, or else you will have speed bumps in your wood. There is a gauge that rides on the knife drum, it is shaped like the letter C, has a bump in the middle, when you are setting the knives, don't tighten them up, just snug them, take your gauge over the edge of the knife, you want it to just touch it, not bump it or pull it, just shave it, snug up the keeper, go to the other end of the same knife, do the same thing, then go back, then go to the middle, then when it looks good, torque it down. Now do the other knife the same way. Make sure you torque them down, double check it. Use a block of wood to tap them in, and the lifter screw to pull them out. Those little 2 edged knifes are not worth diddly, you want a big, one inch knife in there. Something solid. Hopefully that is what you have. You can buy the gauge at woodworker's supply.
Feb 22, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
U will need to check the power switch 1st, this requires testing a "HOT" circuit and you will need a volt meter and knowledge of electrical testing, if the switch tests ok then the motor is defective and will need to be replaced, this should be performed by a qualified repair center, there are adjustments that need to be done after the unit is pulled apart and the motor replaced to insure correct operation of the plainer
Feb 12, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Windows not operating('05 ford f-150)
check your fuses! i bet that is all !
Jul 03, 2009 | 2005 Ford F-150
Adjust blades on Ryobi plainer
go here and pick your plainer and look at manual on top of pic.
Nov 26, 2008 | Tools & Hardware - Others
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Chances are the door panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption of nearby electronic devices. You can find exploded view diagrams and order parts here: We have critical safety and disassembly info at our site, which is linked at our listing here on FixYa:
Feb 06, 2007 | KitchenAid KHMS147 Microwave Oven
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
