Question about Toshiba Televison & Video
Can i put a 57H82 power supply - deflection board in my 61h71 the 2 board look almost exactly the same exept for my pd0074c has 2 caps after the bridge rectifier and the other doesnt but all plugs are the same
  • drjaysevilem Jul 24, 2009
    ok i get that the boards are different but as long as the power supplie part is same it sould work ?
    and in sayin power supplie ur meaning the tpw3450 transistor or the acual first coil on board
  • 261 Answers
As long as the part number for the power supply is the same, yes you can. the thing is that even though if they look alike it might not work, that's why you need to check to part number, remember, they need to be the same one... you'll be able to findit on the back of your power supply
Posted on Jul 24, 2009
Squiggly lines all over untill it warms up then they are just up at the top
Sounds like bad capacitors in the power supply. check for bulging caps or replace the power supply
Mar 13, 2010 | Toshiba 57H82 57" Rear Projection...
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Semiconductors
Electrolytic caps
Regular caps
resistors
inductors/trnasformers
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
Power light blinks - and now the TV won't come on
Most likely the power supply and/or related circuitry has failed.
Charlie
Aug 23, 2009 | Philips Magnavox 27MS343S 27" TV
Toshiba 57H82- Distortions on the picture screen
You have leky caps in your regulated power
supply they are typ 220 uf 200v and are large
and round next to flyback
Jun 23, 2009 | Toshiba 57H82 57" Rear Projection...
Tosh 57h82 flashing led and bad hyper board.
For a service manual, contact Toshiba directly.
Jun 17, 2017 | Toshiba 57H82 57" Rear Projection...
Hitachi 43UWX10B: Power light blinks continuously on and off, no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
RCA P61960 projection screen. no picture, no sound. tries but shuts off.
It will depend on the Chassis number you have but it sounds like a bad Deflection module or a bad Convergence power supply module. The Convergence Power supply module is on the left looking from the back mounted above the deflection module. On newer models the picture tubes can short and put these sets into shut down mode ( Three Trys). Start by unplugging the CRT modules off the neck of the tubes one at a time. If it doesn't come on you have eliminated the tubes. There will be a Red and Black set of wires from the deflection module to the convergence power supply module. Unplug it. If it fires up then it's the convergence power supply module. If not it will probably be the deflection module. The flayback transformer is a common problem along with several bad caps towards the front of the board. Let me know if this fixes it.
Oct 02, 2008 | RCA P61960 61" Rear Projection Television
Toshiba, 57h82
Hire a skilled,senior tech willing to rebuild your board....
replace all bad caps.......good as new.................T.
Dec 19, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82 replacing caps on hyper board
trace them with a continunity meter and all will be ok...
Sep 17, 2007 | Toshiba 57H82 57" Rear Projection...
57h82
Heres your link for the capacitors http://www.mcminone.com/search.asp?keyword=surface+mount+capacitors&btnSubmit.x=8&btnSubmit.y=7&btnSubmit=GO Loads of info here about the board http://www.techlore.com/forum/thread/15237/Toshiba--Model4283--picture-is-zig-zag./ Good Luck
Jul 16, 2007 | Toshiba 57H82 57" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
