Question about Dishwashers
Unit turns on, seams to heat water, but nothing happens when "green" button pushed?
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Posted on Jan 08, 2008
  • 111 Answers
SOURCE: Won't turn on
Your Mainboard is faulty. I had an Eten M600 like that before and ended up it die totally. Eten had many problem with their board. If you still have warranty, contact them for a replacement. Nothing you can do about it since the board is failed to boost due to Power failure.
Posted on Feb 28, 2008
  • 74 Answers
SOURCE: alpine CDA 7843E head unit
if this unit has a motorized face the ribbon cable is bad and will need to be replaced
Posted on Nov 28, 2008
SOURCE: can't get my CyberHome CH-DVD 300 working
Check for bad capacitors on the alimentation fead target
Posted on Sep 01, 2009
  • 5 Answers
SOURCE: Wont turn on
I have the same problem. When I push the green button nothing comes on - just the green LED keeps blinking.....could you manage to find the solution
Posted on Sep 22, 2010
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
The unit will not turn on after trying the pushing the power button. The green light on the reset button shows that it is on but on the display not lights are on. I tried to inplug and wait and plug the...
You need to bypass the on/off switch by jumping it, thereby taking the switch out of the circuit. If it works you have a bad switch. If it doesn't you have a power to the switch problem. Do you have a multimeter and a wiring diagram for this unit?
Aug 02, 2011 | LG Heating & Cooling
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I push the start button (the one with the red light) and the light turns on, but then nothing happens. (Yes, I had water in the tank and coffee in the filter part.) Usually, I push the button, the light...
Sounds like there an issue with the heating element. When the element goes bad it wont pull any water from the tank nor will it heat the water sending it up through the shower head and onto the beans. Unfortunately, since Braun has discontinued ALL kitchen appliances here in the US many of the parts are obsolete including the heating element for this machine.
Mar 29, 2011 | Braun FlavorSelect KF 180 Coffee Maker
Hi, I have a delonghi 3400 espresso machine. When I turn it on, it says "turn the steam knob". I turned the steam knob to "on" and nothing happens. I pushed all the buttons and...
you must purge the machine first, by waiting till the light turns on then slowly turn steam knob until a steady stream of water appears.Make sure unit is full of water.
Feb 17, 2011 | DeLonghi EAM3400 Espresso Machine
Won't turn on or up
If there is a 'lock' button on the heater, push and hold till the green light goes out.
otherwise - tradesmart, energysavers.
May 28, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Won't turn on or up
The function Lock is ON. To turn it off push the v and ^ at the same time for 2 seconds. Then the stove should function normal.
Tom Hawkins
Feb 21, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
Wont turn on
Sep 28, 2008 | InFocus User guide, LP500 / 530 Projector...
Filter light still on "Red"
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
