Question about Panasonic Lands Phones
I have a panasonic KX-DT321 I want to show the company name in the display instead of the incoming number is this possible
  • 201 Answers
SOURCE: panasonic kx-t7639
This would be programmed in the phone system, not the phone.
Posted on Sep 25, 2007
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
Posted on Apr 08, 2008
SOURCE: contact names not showing on incoming calls
save the contacts in the phone memory
Posted on Feb 03, 2009
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
SOURCE: No number or contact name on incoming call.
Hi, I had the same problem few days back. I am using Nokia N95 with a Vodafone service. Any call I receive simply showed "Call" and on checking the call log, says "No Number". this problem is not with the phone, but with the network. I checked with the Vodafone customer associate, I got to know I din't submit my documents to them which is required on an yearly basis and so my phone had this problem. So if u r also having same problem as I had, try contacting ur network service associates and they could help you fixing the problem.
Posted on Sep 24, 2010
Panasonic dect 6.0 plus name and number of incoming calls aren't showing on phones. How can this be fixed?
Do name/number display on any other phones on that line?
If that is your only phone, try borrowing another with working call display from a friend or neighbor. If another phone doesn't display caller info, call your phone company - most charge extra to provide caller number ( and in some cases, another extra to add the name). Even if the features are included in your rate, it's possible they weren't turned on correctly.
Your Panasonic may also have a setting to show name or number - depending on the display size, you may have to pick one or the other.
Finally, some phones do not support exactly the same caller ID info that the phone company sends - I have seen some which displayed number instead of names and no name, just because the two pieces of equipment did not agree on the standard. Try your Panasonic on someone else's line with working Caller ID.
Oct 12, 2017 | Panasonic Lands Phones
How to i turn on Caller ID on my panasonic kx-dt321 phone ? When an incoming caller rings it just says Line 1 . No number is displayed.The 3 other similar phones all have caller ID when someone rings
If I understood users manual which I found via internet,it is digital system for PBX,so it means you can use it 100% if it is programed thru PBX system,so you need to call your IT personel to program it
for you.
Aug 30, 2017 | Panasonic Lands Phones
How do i find out who is ringing on a Panasonic KX-DT321 As all it says is Incoming Call Line 1?
wright done the number the get on the net look for (reverse phone lookup). they will display on a page who it is i use this to idenerfy phone marketers and what counrty they are from.
May 27, 2016 | Panasonic BTS Panasonic KX-DT321 Black...
Incoming caller number not shown, only a "MAIN" is show
What exactly do you mean?. You mean caller ID not showing on other extensions except on operators?
Jan 08, 2014 | Panasonic BTS Panasonic KX-DT321 Black...
Phone Display
Panasonic KX T7633 user manual pdf
the link above is the manual
The Panasonic KX-T7633 is a telephone that will satisfy your demand for a user friendly operation. You can enjoy the hands free conversations offered by the speakerphone facility that the Panasonic KX-T7633 features. The 2.5 mm headset jack that you will find in this Panasonic KX-T7633 phone will enable you a hands free usage for paperwork or PC. It has a 3 line LCd that gives you a readable and clear display. It is available in charcoal and white color. This phone gives you an opportunity to choose the right color that will go along with the d?cor in your home or office. This device looks professionally because of the executive design. The Panasonic KX-T7633 has 24 programmable keys with dual color LED. It also has a 3 line caller ID LCD with back light. You will love the headset jack. It supports caller ID. The Panasonic KX-T7633 has a speakerphone, Intercom, automatic redial and an LCD display. There is a chance for 8 way conference call. It also features a digital XDP (eXtra Device Port) jack. I warmly recommend this phone for your home or office. You will be extremely satisfied. Panasonic phone models are very durable and you can use it for years to come. It will serve well to your every wish. Before using the Panasonic KX-T7633, it is recommended to read the Panasonic KX-T7633 user manual. If you have lost yourmanual, you can always download one here, free of charge: DOWNLOAD PANASONIC KX-T7633 USER MANUAL PDF
Jan 07, 2014 | Panasonic KX-T7633 Corded Phone
Display incoming call icd
As long as this setting is on the lines and if analogue lines a caller I'd card is installed, press TRANSFER while the handset is ringing to change the display
May 15, 2013 | Panasonic BTS Panasonic KX-DT321 Black...
How do i listen to a message on a panasonic kx-dt321
You're subscribed to a voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 03, 2012 | Lands Phones
Caller ID Display
There is no setting in the phone that will show you the Caller ID number without the name. It sounds like your telephone company is not sending the name.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Mar 31, 2008 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
