Question about The Office Equipment & Supplies
Rizo printer rn 2000 ep master jamming by the basket
2 Suggested Answers
SOURCE: I need to repair my riso RN 2100 ep
my riso rn2100 ep have b01-730 error ?
pleas help me .....
Posted on Apr 29, 2013
Riso rn 2030ui error code A01-211
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
Feb 25, 2013 | Riso Office Equipment & Supplies
Rizo ez200E p12-309
Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position.
Try this: Press reset-key. If recovery fails you machine needs service.
Sep 19, 2012 | Riso RZ220 Duplicator
pleas help me .....
Aug 10, 2012 | Office Equipment & Supplies
Error code T01-521 on RISO RN 2130
I have an RP3105 with this error code. Next to the magnetic clamp that holds the master in place is another lever mechanism that lifts the master to present it to the waste master mechanism. This has a small white plastic wheel which is engaged to make it move. On my machine the wheel had broken in half. I superglued the two pieces together and everything works perfectly
Feb 04, 2011 | Office Equipment & Supplies
We have a Rizo 220 ui with an error message
The rear cover may be off. Or you may have a bad cover switch.There are two switches at the top of the back coverone on the left and one on the right. Hope this helps.
Jul 14, 2010 | Riso RZ220 Duplicator
Error code d-17 in rizo rz 200ep
remove master from the drum and reset the master in the master making unit
Nov 30, 2009 | Riso RZ220 Duplicator
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
26 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
