Question about Dryers
Myindesit dryer is very niosy - Dryers
Candy CFD 612 problem
have you checked the filter is the mach niosy if you pull the machine out lower the drain hose into a basin and see ithe water runs out if you tilt the machine backwards before opening filter you will have less chance of making a mess hope this helps
May 10, 2014 | Candy Washing Machines
Machine flashing fd 50
okay take it to the shop you bought it from and ask them to help you
Dec 10, 2013 | Washing Machines
Replace colour wheel because of a high pitch noise, now the TV comes on and shuts off right away. Any ideals, the balast and lamp are fine. Bill
If you had a pix before just a niosy color wheel then I would double check and make sure you have the right one for that engine. Next, re check all your connections. I hope you have the lamp door in place?
Dec 10, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Washing machine makes a loud vibrating noise when spinning and sprays grease onto washing
It sounds like the main bearings have failed, try turning the drum by hand, if it feels rough or is niosy, then the bearings have failed.
Oct 25, 2010 | Hotpoint Washing Machines
I have sony laptop model PCG-3E2l A fan is bad. where I can i buy a Fan, what is a part number. Thank
I've the Same Problem but I need to change the Fan myself so I need to know the disassembing for this version plz
Nov 16, 2009 | Sony Computers & Internet
Loud noise during tub draining
If it is only niosy when draining, then I would check the pump or filter for something caught in it.
Please rate my solution.
Jul 28, 2009 | Whirlpool LHW0050PQ Front Load Washer
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
May 27, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Noisy clutch
I believe they all do that sir. Certainly mine does and has for the 10,000 miles I've put on it.
Nov 10, 2008 | 2005 Triumph Speed Four
Noisy dryer
It is probably a motor bearing. My Lavatherm had a constant noise while running. It had a clogged drainage in the fan, causing water in one of the motor bearing and after som time the bearing worn out.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
23 people viewed this question
Top Dryers Experts
