Question about Uniden Lands Phones
I have a uniden 36 and I keep getting the message "user is locked"
My uniden DECTm1580 cordless phone with answering machine will not let me get my messages remotely
have you followed the user manual and set up the correct dial in code to get your messages
Jun 18, 2017 | Uniden Lands Phones
My uniden guardian will not accept a new s.d. Card the monitor keeps saying card error,what do i do?
Louie,
According to the Users Manual, the Uniden Guardian will only take up to a 32gb micro sd card. They also recommend that you format the cards every 4-6 weeks for optimum performance. Refer to page 36-37 in the manual for more info. Hope that helps!
Mar 01, 2014 | Uniden Guardian with 4.3 Touch Screen
Uniden Dect 6.0
Since you didn't specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl to download a copy of the manual. It will explain how to switch languages.
Jun 08, 2013 | Lands Phones
How do you turn the ringer on
With the phone in standby, press up-arrow on the handset or Volume+ on the base. Full details are on page 36 of the manual.
Sep 09, 2012 | Uniden DECT15803 Trio Cordless Phone
I nead a mauual for uniden cordles phone # un-2280-3
Send a message with this request to info@uniden.com to get a complete user manual sent to you for free. Although this could take a couple of hours to get a replay but you should get the user manual sent to you.
Hope this solution has been helpful?
Jun 20, 2011 | Lands Phones
Message waiting light will not go off
Found a user manual online. Solution is holding the "Find Handset" button in for five seconds, until the red light went off; that reset the message waitung light and message.
Jan 23, 2010 | Uniden Cordless Phone
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
How do I get messages?
Here is a link that you can get the manual, You need to find your model# in the list then you can download the manual.
Hope this helps
http://www.uniden.com/index/manuals_results.cfm?cat=1
May 05, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Programming error BCT8 Uniden
Hello.
Back to answer my own question.
I just found the problem. If you try to program one of these scanners (Uniden BCT8) and you keep getting a "pr9-loc" message every time you try to enter a frequency and "M-LOCK" is showing in the upper right corner of the display press and hold the M-Lock (E) key until it beeps twice and "M-LOCK" disappears from the display. You're now set to program.
Keith.
Dec 30, 2008 | Uniden BCT8 Base Scanner
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
