Question about Refrigerators
The temp will not come on - Refrigerators
  • Mike Smith
    Mike Smith May 11, 2010
    Sorry , your question makes no sense . Brand and model number and a more accurate question would be more feasable .
  • Refrigerators Master
  • 4,655 Answers
Unplug your refrigerator and remove the cover over the controls. Take the two wires that go into the back of your thermostat and straight wire them. Replug and if the compressor starts cooling then replace the thermoststat. Sea Breeze
Posted on Jul 25, 2009
Digital temperature changes to 86 every time your set it to a lower temperature how do I fix this
If this set temp changes on its own then the circuit board has failed. Call a service tech or replace the unit. But this 86° might be the indoor temp, not the set temp? If I set my temp to 75°, then my temp goes to 86°, then the set temp (target temp) is 75° & actual room temp is 86°. The unit may not be working properly. Not sure if this helps.
Jun 13, 2015 | Haier Heating & Cooling
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
South seas spas
need more info. will temp lower? if temp lowers try setting up to 104 if desired temp will not increase sounds like you need temp adjustment switch if desired temp goes up to 104 but water doesnt
sounds like temp sensor if temp sensor is good heater element
Feb 16, 2014 | Pool & Spa
What temp should a/c be in 1995 chev on max
Hard to say.
Under normal conditions, vent temp should be about 20 or 25 degrees less than outside air temp.
So if outside air temp is 90 degrees and the engine is at idle speed, vent temp would be around 65 or 70. On the road the vent temp could be less than 60 degrees.
If outside air temp is 70 degrees vent temp will be around 40 - 50.
Jul 21, 2012 | 1996 Chevrolet K1500
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
Oct 06, 2017 | 2002 Chevrolet TrailBlazer
Temp runs only 180 degrees. High temp thermostat
yes thermostats wear out. make sure your cooling fans are not running at the low temp you have. you may have a bad temp sending unit. also you gauge send ing unit could be bad.
Dec 28, 2009 | 2003 Buick Park Avenue
Getting a low coolant temp code.temp is normal. im
Sometimes there are two Temp sensors. Did you see if you had two?
Jul 29, 2009 | 1997 Toyota Tacoma
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
