Question about Vacuums
Model F59150900 Burnt smell in conjunction with less than powerful motor sounds. I do believe that the brushes are not engaging.
    President:
  • 1,273 Answers
Usually a general cleaning and minor maintenance is all that's necessary to repair a vacuum. Here's how you do it:
With it unplugged, flip the offending machine beater bar up. Remove the base plate and check that the beater bar still has the belt on it. Rotate the beater bar and feel for resistance. On some models, hair and debris tends to wrap around the beater bar and the beater bar bearings. Carefully remove the beater bar. The bar rides in sockets in the vacuum frame, so make mental note as to how it comes out, making reassembly much easier later. With the bar out, remove any hair, etc built up on the ends. Now is also the perfect time to inspect the vacuum cavity behind the beater bar.....this is where they usually plug up. Inspect the belt, and run your fingers along the inside of the belt. If a belt has become stuck it will erode a groove across the belt. Check it also for cracks, etc. Anything less than a great looking belt should be replaced. They also stretch over time, so if your's is old.....
With your fingers, spin the motor shaft, where the belt rides on it. It should turn freely, and continue to turn after you let go. If the motor works OK, and you like the condition of the belt (or have replaced it), reassemble the machine in reverse order.
Hope this was all you needed. Feel free to rate this answer.
Best regards, --W/D--
Posted on Jul 24, 2009
    Scholar:
  • 86 Answers
Sounds like it broke a belt. They do smell awful.
My Riccar vacuum was working but then just stopped and won't turn on. I changed the bag even. What's up?
Hi Patty.
Could be:
Power cord. Check esp. strain-relief where cord enters housing.
On/off power switch. Needs strip down & continuity check.
Motor burnt out. Smell if burnt. Strip search.
Carbon brushes inside motor worn. Dismantle & check / renew.
Does this help?
Regards, Clive.
Nov 05, 2017 | Riccar Vacuums
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Motor smells Oreck Xl2
If it smells electrical, than you may need a new motor. If it smells more like burnt rubber, than you may have a brush or motor problem. To check you brush, take out the 5 screws that hold your bottom plate on the vacuum and remove the plate. Disengage the belt and see if the bearings at each end of the brush turn freely. If they do not, replace your brush. Also spin the motor shaft by hand and see if it turns freely. Hope this helps!
Mar 02, 2015 | Oreck XL21 Bagged Upright Vacuum
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
Smells like burning
We had this same issue. I noticed it smells like burning plastic. I took it apart and did not find any fundamental problems. Ball bearings on motor are fine, no play. What I did find was that the motor construction contains lots of plastic. It's made in China. Even the brush holder is plastic. Now, this is unusual to me, as brushes get very hot. However, I did not find any issues of melted or softening plastic when running. I used a laser-guided thermometer and measured about 170 degrees F on the metal portion of the brush holder. Nothing unusual. Some parts reached above 200 degrees F. Again, nothing unusual. The only unusual issue is that many of the parts are mated with plastic parts. That's where I believe the problem lies. When the motor is new, the brushes don't make full contact. Therefore, full power draw is not achieve until these brushes wear down a bit. After this point, the brushes reach maximum power delivery and reach maximum temperatures. This is why I believe the vacuum didn't exibit any smell until a few months later, at least, for us. In conclusion, I didn't find anything wrong, except that the motor is cheaply constructed. It isn't going bad and well likely last quite a while, IMHO.
MAJ
May 01, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Wind tunnel two with bag, started with burning smell then shut off with red light on. Belt is fine but cannot get it to start again.
Sounds like your motor.Try replacing the brushes in the motor.If that does not work then the windings in the motor have burnt out.
Aug 01, 2009 | Vacuums
M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Fantom Lighting Power Head
The red light tells you that that there is a clog, either in the hose or down by the brush roll. The smell if it is rubber smelling, then it is the belt and maybe the brush roll. If it is an electrical smell, then probably the motor. But parts for these are always available, they went bankrupt several years ago and aren't in business anymore.
Mar 24, 2008 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
212 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
