Question about Camping, Backpacking & Hiking
Black and Decker Lithium Halogen Spotlight will charge after 5 seconds the LED idicator turns red and light goes out release trigger light will come on then go back out.HELP
  • 1077 Answers
SOURCE: will not turn on
This might help you. Try starting on page 27 of this:
Posted on Apr 05, 2009
  • 3866 Answers
SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ I hope this helps.
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: My dell D810 won't power up.
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Posted on Feb 18, 2010
  • 111 Answers
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Posted on Mar 16, 2010
  • 11361 Answers
SOURCE: i turn it on and it comes on for a second then the goes black
You need to open it up and inspect the capacitors (look for bulging top/seal), burnt inverter transformers, resistors, etc. in the power supply/Inverter board first, post back what you find so we can guide you further. See example of failed Viewsonic monitors:
Ihave a black and decker drill.The charger shows a flashing red light and does not charge the drill
Try inserting battery quickly 5 or 6 times to see if it is just a connection problem, sometimes this works in cleaning the terminals.
press the helpful button.
I think the red blinking light is a fault, normally should be a green flashing light while charging.
Jan 18, 2016 | Drills
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
The spotlight/flashlight battery may have failed as a result of being unused and not charged periodically.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
Why wont my lithium ion led spotlight hold a charge
I would assume your battery is no good
They last 4 years on average, I would guess
Sep 30, 2014 | Black and Decker USA Black & Decker...
VEC157BDC Spotlight
remove the black rubber guard from the front there is a screw on each side remove them then remove the lens guard then you can get to the bulb. I hope this helps. You will need a phillips screw driver and a flat head one small ones
Jun 14, 2014 | Black and Decker USA Black & Decker...
I have a Black and Decker Lithium Halogen Spotlight and need to know how it comes apart to replace the bulb. thank You
Pry off the rubber bezel with a flat head screwdriver, remove the Phillips head screw holding the reflector in place. to remove bulb you must loosen the phillips head screw and nut holding bulb in place , do not touch the bulb with bare hands use a paper towel or cloth, the oils in your skin will cause premature failure of bulb.
Sep 11, 2013 | Black and Decker USA Black & Decker...
I have a Vector HID Spotlight Power on Board SLH100P and I'm trying to recharge it. When you plug in the charger the led lights flash and click really fast. What could be the problem? Thanks for your...
The battery needs replaced. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from:
Aug 04, 2010 | Vector 1 Million Rechargeable Spotlight
Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
Jun 10, 2010 | Vector 1 Million Rechargeable Spotlight
Light wont light up
The rechargable battery is dead, it has just enough juice to light the LED but nothing else. You can order a replacement battery from All Vector Products, Service and Parts are sold by Black and Decker which purchased Vector in 2006. The products are rebranded under the Black and decker name now.
May 19, 2010 | Vector 1 Million Power Series Spotlight &...
check the factory date.. the batt might be bad due to time, check the polarity conexion to the batt might inverse. i suggest u try another batt..
Mar 15, 2009 | Black & Decker Black And Decker 2 Million...
Camping, Backpacking & Hiking Logo
1,089 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
