My LED TV, it was working, but in a sudden went black screen. it still has back light, with sound but no picture. I tried to replace the T-con Board, but not working.
  • Piotr Pachkaev Apr 19, 2017
    Maybe the bad connection is the reason. It usually happens with improper installation or a poor quality cable.
SOURCE: TV Won't Turn On
I purchased the TV using AMX card 18 month ago. They have an extended 1 year warranty on top of manufactory's. I just have this set repaired: replaced SD board, total charge is $550. I already file a claim and hope to get reimbursed soon.
Posted on Mar 06, 2008
  • 1139 Answers
SOURCE: black screen
This denotes a power supply issue. I would venture to say that it is the part of the supply that controls the plasma ignitor if this is a plasma TV or if this is an LCD screen it is called the back-light and inverter circuit. The power supply board would be the chief culprit in this case.
I hope this helps,
Thank you,
Posted on Aug 21, 2008
  • 63 Answers
SOURCE: Last night, while watching the plasma tv, the
Very common issue with Plasma TV's. Unfortunately there's no common fix, or easy fix either. The symptoms you described could be caused by a bad power supply board (not likely), a bad video controller (maybe), or bad X, Y, and/or Z sustain boards (most likely).
If you're handy with a screw driver, you can take the back off the TV and have a look around. Make sure you unplug it from the wall and maybe even wait for an hour or so before opening it up. This will allow it to discharge any stored electricity, though it's not a guaranteed safety net. Work as though anything you touch might shock the sh*t out of you. Because it might.
What you're looking for is signs of a failed component. Capacitors will often bulge on top when they go bad. IC's sometimes will crack, bubble, warp, or burn. Sometimes you can see that a general area of the circuit board appears darker, and often this will be where something has broken down.
Should you see anything that just doesn't look right, and you're pretty sure that it's bad, you can look for that board part number online and sometimes find a really fair price. From there it's all plug and play. A couple screws, a couple wire connectors, a trip to the hospital because you touched a charged cap, and that's it! Voila! Your TV will be up and running again.
Boise LCD
Posted on Dec 16, 2009
  • 63 Answers
SOURCE: 50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Posted on Aug 03, 2010
  • 4889 Answers
SOURCE: My 42 inch Maxent went
Whn the sustain boards go out, its usually due to the buffer boards. Since you have already replaced the sustain boards, replacing the buffer boards should do the trick as these are the boards the control the firing up of the gas inside the PDP(Plasma Display Panel).
Posted on Mar 19, 2011
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
Samsung LED TV problems
try first with the led strips noo need replacing t-con
Feb 27, 2017 | Samsung UN40ES6100 - 40" 6 Series...
After a thunder storm i have sound, no picture, the tv powers up, the back lights are on, should i suspect a bad lcd screen?
Something else is going on. The T-Con board has no other function than controlling the picture. If there is a separate board for the led drivers, I'd suspect that one. The main board controls the sound.
Mar 11, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
Why does my TV have no picture but still have sound? Its a LG LED Tv Model number 42LS3400-UA prod code 42LS3400-UA.APHLJD Serial number 2101NBSB2837 When turned on there is sound but no picture.
the picture board has gone faulty
thee are two system boards in the set --one for sound and one for picture
if you have the number from the board you want to replace try e-bay --circuit boards for your tv and see what comes up
Feb 22, 2016 | LG 42LS3400 42" Class FuHD 1080p LED LCD...
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ... > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
TV screen went black, sound is intact, can I fix it?
This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
Mar 02, 2015 | Televison & Video
No picture
If you look very close at your screen (might need flashlight here), do you see the picture as a black screen? If so, your backlight may have died on the panel. Replacing the inverter board will fix that right up unless the tube (lightbulb) has burnt out instead of the board. Both are replaceable.. Check it out.
Aug 17, 2014 | Dell 221-9495 W5001C 50 INCH PLASMA TV...
Televison & Video Logo
Top Televison & Video Experts
